Something metal fell off my car...
Car: 1986 Trans AM
I was driving around last night, and as I turned onto a street, I accidentally slid my back tires out and ended up jerking the car around really hard as I tried to correct it.
Two seconds later, I heard what sounded like a small piece of metal clanging against the concrete behind me.
I couldn't find anything when I looked under the car when I got home. Is there anything in particular I should be looking for?
1 Post
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
Re: Something metal fell off my car...
Lots of metal things on your car that can rot off... Exhaust is usually the first thing to go...
Car: 1986 Trans AM
My exhaust hangars have definitely seen better days lol. I'll take a look at those. Anything else I should be on the lookout for?
1 Post
Could be a million things. Examine all the critical systems to make sure the car is safe to drive, then don't worry about it too much.
Car: 1986 Trans AM
I mean it sounded like something fell COMPLETELY off the car. There is nothing dragging or anything.
LoL at even ASKING that question.
If the panhard broke on the car you would KNOW instantly. And by instantly, I mean in that "Oh God, Oh God, I don't WANNA DIE!!!" way. I once had my panhard bolt get a tiny bit loose. Enough to introduce about maybe 1mm of left to right play in the mounting. The side to side motion as the car changed lanes was terrifying.
If you actually LOST the panhard bar? You'd wreck the car the minute you put any side load on it. The axel would slide out from underneath you. You would have ZERO control over the car.
Car: 88GTA
Engine: 5.7TPI
Not knowing what kind a car you have, Buick, Mustang, Camaro, Firebird and so on....do you have all wheel center caps??????
1 Post
There is nothing dragging, so he's not going to hear anything. Like the title says something fell off. Its completely gone. Not dragging, not scraping, gone.
Car: 1986 Trans AM
Lol, sorry y'all. It's an '86 Trans AM. I finally have some time tonight to give it a close look, so I'll see what I find
Look at the end links on your front and especially rear sway bars . They have hardware that rusts/rots and can allow pieces to fall off . If one breaks it can drop up to 4 metal washers and one metal sleeve on the ground and that would have a metallic clanging sound as they hit the pavement .
Car: 1986 Trans AM
The test results are in It was a busted exhaust hangar... which gives me an excuse to get started on putting a proper exhaust system on this car
Car: 1988 Camaro
If you live anywhere close to the west part of Georgia I have 2 nice aftermarket exhaust systems for sale at a fair price.
Car: 1986 Trans AM
Engine: 4++,350 & 305 CIs
I'm 1 hr north of ST Louis. I have a stockish exhaust system from the cat back for stupid cheap if you want it.
Night rider327
02-25-2016 09:50 AM
bigjay89gta
10-15-2015 08:04 AM
sjorgens
10-01-2015 07:54 PM
