Odd problem
Car: 1989 Firebird Trans Am
Engine: 355
Odd problem
The car doesn't start on it's own. If I add a spray of starting fluid it starts instantly. Idles perfect at 500rpm in gear and 1,000 in park. Sounds normal, no bogging down or stalling. Doesn't even try to die. Fuel pressure says 45psi. Tps is at exactly .54 volts.
