converting to ss braided lines & AN fittings
Old 08-10-2015, 09:24 AM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
I've searched and there's hundreds of threads on AN fittings but I haven't been able to find one that lists all the needed part numbers for my application. '89 firebird that was originally a 305tbi and I'm finishing up a 350 swap with a quadrajet. Does anyone happen to have the part numbers or a link? Already have a mallory 4309 btw. So far I've got 9894dbherl and 9894dbjerl which run from the factory feed and return lines.
-thanks in advance
Old 08-10-2015, 07:11 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
Re: converting to ss braided lines & AN fittings
Bump
Old 08-10-2015, 07:35 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Brake lines or hoses or what? I would call Earl or Russel or whichever manufacturer you are going with and discuss it with them. I am guessing you want to do the heater hoses, radiator and fuel lines?
Old 08-10-2015, 07:58 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
Just got off the phone with Summit and they were able to square me away with everything except for which size fitting I need for the inlet of my quadrajet. But I don't have the carb near me so I may have to wait. I decided to go with stainless Teflon hoses - summit sells some $43 shears for cut these, is there anything cheaper I'd be able to pick up around town or should I just bite the bullet and get those?
Old 08-10-2015, 08:00 PM
SbFormula's Avatar
Car: '91 Firebird Formula
Engine: SP383 Deluxe FIRST® TPI Intake
Transmission: Tremec T56
Axle/Gears: Moser 9" Eaton Truetrac Motive 3.89
Call Summit Racing. They have Russell and Earl. They even have specialty fittings for match with OEM fuel lines to custom hoses.
Best of luck!
Old 08-10-2015, 09:23 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
Would 6 ft of hose be enough for the lines to the regulator then to carb?
Frozer!!!
01-19-2024 04:55 PM
MustangBeater20
Carburetors
08-21-2015 02:42 PM
Jake_92RS
08-17-2015 09:42 AM
Leggman1
Brakes
08-12-2015 08:39 PM
Quick Reply: converting to ss braided lines & AN fittings
