Only half of lifters getting oil. help.
Old 08-18-2015, 11:52 PM
Cameeeero's Avatar
was priming my engine with a handheld electric drill with the rocker arms off and only the lifters on the driver's side were getting oil. I installed the rocker arms on the driver's side thinking maybe they would make some back pressure but still not a drop came out of any of the passenger side ports for the lifters. this is my first sbc build so sorry if I sound naive in any way. Do I just need a bigger drill or might there be something blocking the oil flow to the passenger side. Thanks!
Old 08-19-2015, 12:51 AM
Night rider327's Avatar
Car: 1988 Camaro
Re: Only half of lifters getting oil. help.
Really common... Rotate the engine by hand using a crank socket, damper bolt, breaker bar, or by grabbing belt..
Turn engine a few times... Then reprime oil... It will take about 6-10 min of running the drill to get full oil pressure to both sides. I have burnt many of cheap drills up doing this over the years. I now use a corded 1/2" high torque hammer drill with option switch for smooth non hammer drilling
Old 08-19-2015, 08:02 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Night's correct, it does take a while. Only thing, does your priming tool have a oil groove piece near the bottom. Otherwise the oil can't cross over the banks they way chevy intended.
Old 08-20-2015, 03:06 AM
Cameeeero's Avatar
No my priming tool does not have that. I feel so silly having missed that.. Off to summit!. Thanks!
FormulasOnly
07-23-2018 08:47 AM
Thornburg
Aftermarket Product Review
10-06-2015 12:04 PM
skinny z
10-05-2015 06:23 PM
Numbah-1
10-02-2015 08:27 AM
drumstixer
09-29-2015 03:02 PM
Quick Reply: Only half of lifters getting oil. help.
