Help! 305 Tpi runs really bad after a while!
Old 08-19-2015, 12:07 PM
Hellbillydeluxe's Avatar
Car: Camaro Z28 1991 Convertible
Transmission: Manual
Hi!
I'm getting desperate here!
I have a -91 Camaro z28 convertible with manual gearbox.
This spring it started to die when i whas driving and after a while pressed down the clutch. No errorcodes. I have changed sparkplugs, ignition wires, the temperature sender near the intake, changed the IAC, meassured the injectors. Today when i went for a testdrive after changing the IAC it started to missfire after 20 minutes at low speed. When i got home i checked for errorcodes by flashing the service light. Now the fan and the enginelight whent on and off randomly! Computerbox failure?
Link to youtube https://youtu.be/kNqUL5tjuCA
Please help!
Marcus
Old 08-19-2015, 02:02 PM
Re: Help! 305 Tpi runs really bad after a while!
This is ehat happened when i tryed to flach codes, listen to the relay!
The fifteen minutes later all was normal again!
There in a Superchip installed maybe something wrong with that?
Old 08-19-2015, 06:28 PM
ex-x-fire's Avatar
When its running bad check the fuel pressure.
Old 08-20-2015, 12:28 AM
I will change the fuel filter if that is bad and also check for groundproblems to the ECU.
To be continued.......
Old 08-23-2015, 11:45 AM
Hi!
I am looking over the wiering and came across this terminal. Looks like it been pretty warm. Anyone know what it is for? Located on the upper passengerside.
Old 08-24-2015, 11:40 AM
I have found what was causing the burning smell. Anyone know what its for, can it cause the missfiering?
Thanks / Marcus
Old 08-24-2015, 09:45 PM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
Knock sensor and yes it'll cause a host of problems.
Old 08-26-2015, 12:18 AM
Problem solved!
That is the radiator fan switch, and with it disconnected the car runs fine!
Won´t get any errorcodes from that, and with a bad Connection the ECM failed and the car missfired and no idle. Drove 7 miles yesterday with no problem!
Thanks for the input!
Old 09-21-2015, 09:09 PM
judoka_ca's Avatar
Car: Camaro IROC-Z28
Engine: 5.0/305
Transmission: 5 Speed
Originally Posted by Hellbillydeluxe
Problem solved!
Hey are you sure that was a radiator fun switch not a knock sensor ?? as the one on the photo had a white wire and as I remember correctly it should be a black wire for fun switch and white wire for Knock Sensor that should be mounted close by
Old 09-22-2015, 12:11 AM
Yepp, sure. when i ground it the fan starts. Electric schematics says grey. Black is to the fan.
Old 09-22-2015, 09:58 PM
CatmanFS's Avatar
Car: 85 Z28
Engine: 93 LT1
Axle/Gears: 3.73 01 SS
Yeah that little fan switch uses the same connector as a knock sensor. That fan switch has always been a mysterious little guy. Just one of those things that always seems to come up eventually.
BlueIroc-Z
06-09-2019 03:22 AM
1nastygta
10-28-2015 08:51 PM
st.evel07
08-13-2015 06:15 PM
squiggy2
08-09-2015 09:30 PM
drathaar907
08-06-2015 04:20 PM
Quick Reply: Help! 305 Tpi runs really bad after a while!
