zz4 vs l98
Car: 1989
Engine: 5.7
Transmission: auto
Axle/Gears: 2.77
zz4 vs l98
I'm confused with all my reading here, to the point if i put 113 heads on a l98 I do not get the 400tq the zz4 has. if I put the zz4 cam in the l98 also does the l98 with it's ltr out tq the zz4.
or do I have to go carb with it's manifold to get the tq. I always thought the ltr was the tq king but i'm looking at the zz4 an thinking that's a sweet running motor for my 89 Iroc.
why does the corvette l98 or does it not pull the tq #'s the zz4 does. I'm at a loss here...if I get the answer the ltr just can't keep up with the carb in this case I'm thinking I'm going carb if I do anything...Dan
Engine: 4++,350 & 305 CIs
Re: zz4 vs l98
As said, you will gain TQ with that motor under a TPI but lose out on the HP with a TPI.
Car: 89 Firebird
Engine: 355 TBI
Re: zz4 vs l98
In love the looks and the gas mileage of the TPI system but it does have its limitations. A friend of mine swapped over to a carb and performance intake manifold on a stock L98 and went from mid 14s to upper 13 sec 1/4 passes. The car went from running out of air at 4500RPM to pulling strong to 5500 or so. I myself would probably rather have the fuel injection but sometimes its so troublesome its not worth it to fool with. Ive pulled a cross-fire setup and a TPI setup before after many headaches and cursing sessions with it. LOL
Car: 1989
Engine: 5.7
Transmission: auto
Axle/Gears: 2.77
Re: zz4 vs l98
Thanks for the replies much appreciated, an I'm rambling it seems so thanks first
that's the way I was thinking it would go also more torque less hp. the people who have Siamesed the ltr base seem to point to a bottle neck at the injectors as yet another hp holding back point. I would think a Siamesed base would be great myself but maybe get the injector area opened up would be good an leave the runner intact. an I was thinking of concentrating there first.
with trying to use the zz4 as a goal, my stock heads need to come off there some day anyway. with a stock tpi an the zz4 cam an heads (low miles heads in good condition an price) as a possible plan.
I have an extra stock tpi base I intended to open up. if I could pickup the zz4 manifold an carb, heads an cam I would be temped to. I buy the idea a street driven car does not need all that hp but I would never give any back because I don't need it. if the guy comes through with the heads I may go this route..
any Idea's on what to do with the extra stock base it needs a lot of work I know.. an really if these heads don't come through others are out there. I'm leaning to less cam than that hot cam I picked up. all this can be wiped out with a dif manifold an it's really temping my car has been stock so far an this is just crazy it seems...Dan
Re: zz4 vs l98
MikeJR1991 (02-10-2022)
