About 4-5 mpg less after straight pipe??
Car: 92 RS
Engine: 305 TBI
I finally straight piped my car (still has mufflers just no cat). Immediately I noticed a huge loss of fuel economy, about 15mpg average instead of 20mpg average. I always drive about half freeway half city and I didnt change my driving habits. I did get on it kinda hard when I first got it back, but even the next 3 fill ups, I still noticed that Im not getting anywhere near the same gas mileage.
I wouldn't mind a little loss of mileage but it seems like too much of a loss. What are you supposed to do with the air tube that goes to the cat? Im pretty sure the muffler shop just left it there open.
Also the car still seems to run a little rich still even with the new o2 sensor (hard to tell with no cat but it seems to smell more than my friends 69 chevelle with a 350). I think its a vacuum leak because im still having intermittant problems at full throttle (made a thread about that earlier)
So anyway did anyone else notice the loss of fuel economy after removing their cat? Anything that can be done?
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Re: About 4-5 mpg less after straight pipe??
Removing the cat should not reduce your fuel economy at all. Something else it going on.
Car: 91 G92 Z28
Axle/Gears: 342
My car smells rich after removing the cats too. I think that's just a byproduct of removing them. Have you pulled some plugs to get a visual on it possibly running rich?
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
Check for exhaust leaks before the O2 sensor or after...that could impact the readings. Also, what brand of O2 sensor did you use? Better be Delco for proper readings to ECM.
Do you have headers? If so, then a heated O2 sensor should be installed.
Car: 92 RS
Engine: 305 TBI
I used AC Delco o2 sensor. I do have headers and I retightened the bolts. I dont have a heated o2 sensor though
Car: 92 RS
Engine: 305 TBI
Engine: LS3
Transmission: 6L80E
With headers, you typically need a heated O2 sensor, so the ECM will go into closed loop. The AFS-74 is one that I have used...do a search on heated O2 sensor on this site for more info.
[Sold] Flowmaster exhaust system
Night rider327
10-09-2015 09:25 AM
LT1Formula
10-08-2015 08:34 PM
