Engine won't start no spark at the plugs
Old 09-06-2015, 01:44 PM
Jlanz55's Avatar
So my car ran last week and now all of a sudden I'm getting no spark to the plugs. I replaced the cap rotor and coil to the distributor. Any help please! I have no clue why it work fine for years and all of a sudden nothing
Old 09-06-2015, 02:58 PM
Jlanz55's Avatar
Re: Engine won't start no spark at the plugs
Also just replaced the ignition control modual and still nothing...
Old 09-07-2015, 12:43 AM
Night rider327's Avatar
Car: 1988 Camaro
Did you check for a blown ignition fuse?
Old 09-09-2015, 09:09 AM
MM2Robinson's Avatar
Car: 89 Firebird Formula
I literally just went through the exact same thing in my 305.
I replaced the ICM, rotor, cap, plugs, wires, coil, checked fuse, wire-brushed everything, and nothing... Until I replaced my distributor, which baffled me that it went out so quickly as well.
I would check power to both ends of the coil connectors (in and out to ICM).
If you have power there, then I would pull the center plug wire (from coil) off distributor cap, put a spark plug in it, ground the threads and see if you're getting spark there while someone is cranking it over for you.
If you have spark there, then unfortunately your problem is in your distributor.
If you don't have spark there, then try swapping out the center plug wire (between coil and center post on distributor cap).
See what that does
Azrael91966669
25
06-20-2017 04:04 AM
Spyder_TheGamer
12-25-2015 05:07 PM
Brcharrelson
08-26-2015 07:47 PM
djmarch
08-09-2015 05:27 PM
Quick Reply: Engine won't start no spark at the plugs
