Strange ECT Response over time
Old 09-20-2015, 12:18 PM
BWilcox's Avatar
Car: 87 IROC
Engine: 420 EFI
Transmission: TKO500
Axle/Gears: Moser 9" 3:50
Hi Guys,
I had to fix a leaking cylinder head plug on my engine.
Before the "fix", the ECT sensor readings were normal. Please see the "normal" picture.
After the leaking plug fix, I filled the cooling system with new coolant and noticed some strange ECT behavior. Please see the "weird" pictures.
I have checked the wiring. No problems detected.
The engine coolant level is now stable. So I assume the system is packed with coolant and any air bubbles are long gone.
No error codes are reported.
The dash gauge appears to indicate the expected (180 F) temperature. I do not look at this gauge frequently while driving. So some observation error is possible.
Thoughts:
1.
The ECT values are not at end-limit values. So I have assumed the wiring is not intermittently shorted or open.
I have moved the wires around while data logging and do not see any response change that is associated with the wire movement. Vibration should not be an issue.
I have moved the wiring harness by the ECM (7730) and did not detect strange ECT readings.
Other things to try?
2.
Other sensors, IAT, EOT, and TPS seem ok.
3.
I forgot to turn on the heater.
Wonder if I need to get the coolant to run through the heater core to fully purge the coolant system of air?
Comments?
4.
Wonder if I have a gas bubble around the ECT location?
Running a TPIS MiniRam II.
Comments?
5.
What about a Thermostat that is not fully open?
My Thermostat opens (ideally) @ 170 F. Yes, I live in NC and it gets hot in the summer. This car is not a daily driver.
I noticed the ECT value seems to climb during longer runs and cool when at idle for a period of time. Just wonder if a partially open thermostat would restrict (too much) the coolant flow and result in partially higher short-term coolant temperatures?
Comments?
Thanks for any trouble-shooting suggestions.
Things were just fine a couple of weeks ago.
Best Regards,
Bruce
Old 09-20-2015, 12:19 PM
BWilcox's Avatar
Car: 87 IROC
Engine: 420 EFI
Re: Strange ECT Response over time
Looks like the attachments were not attached.
Attached Thumbnails Strange ECT Response over time-ect_normal_full.png   Strange ECT Response over time-ect_weird_full.png   Strange ECT Response over time-ect_weird_zoom.png
Infested
05-22-2018 11:56 PM
red90IROCls1
08-25-2015 06:56 AM
gta power
08-13-2015 06:15 AM
ZsTransAm
08-11-2015 07:30 PM
Ginamariegault
Brakes
08-10-2015 08:33 AM
Quick Reply: Strange ECT Response over time
