anyone know what part this is???
Hello I own a 1984 Chevrolet Camaro z/28 it has a 305 motor with smog system. I cannot figure out what part this is does anyone have a clue what this part is?
Car: 1986 Z28
Engine: 383
Transmission: 5 speed
Axle/Gears: stock 10 bolt at this time
Re: anyone know what part this is???
I'm not sure of a correct name, but it looks like the same part I have in line from my power brake booster and the vacuum port in the rear of my carburetor. Seems to be some type of check valve.
Engine: 4++,350 & 305 CIs
Looks like a air inlet muffler/filter for the smog pump.
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Agree with TTOP350 and Paulo... muffler/silencer.
Air is drawn into the smog pump through the front slots, behind the pulley. When air is not going into the exhaust manifolds nor to the cat, it has to go somewhere... which is back to the atmosphere. If you just dump it, you'll hear the pulsations of the pump pressurizing the air, somewhat like a blow-off-valve. GM didn't want this mystery noise to appear at certain times, therefore an air pump outlet muffler.
FueledSoul
09-26-2015 12:00 PM
1Aauto
Sponsored Vendors
09-23-2015 12:50 PM
firebirddude142
09-23-2015 11:36 AM
CAMAROBEAV
European Region
09-12-2015 09:34 AM
