Ground bolt for LH cylinder head. anyone know the size?
The bolt for the grounds is gone. I can't seem to find one that fits. Does anyone know what size it is? Thanks
Re: Ground bolt for LH cylinder head. anyone know the size?
Should be 3/8-16, maybe 3/4" long. You can always unscrew a bolt from the front of the head to see what you're working with.
Car: 1988 Camaro
Yep 3/8-16 thread,
1/2 to 3/4" long.
I find header bolts works perfect for the ground strap wire and some how I end up with a coffee can full of used header bolts so that's what I use
1/2 to 3/4" long.
355tpipickup
09-28-2015 05:50 PM
