TPI Vapor Canister Hose Routing
Car: 92 Camaro RS
I have a 1992 Camaro I have upgraded from a 305 TBI to a 350 TPI. I have a diagram of how to connect the vacuum lines but a question on the routing. How does the vacuum line from the throttle body (the larger one on the passenger side) to the canister route. Any diagrams or pictures would be appreciated.
Car: 92 Camaro RS
Re: TPI Vapor Canister Hose Routing
Thanks for the info. Would you be kind enough to look at the car. The question is does the hard line make a 180 degree turn or does it make a 90 degree turn and then connect with a 90 degree elbow or does it connect in some other way. Thanks.
Car: 92 Camaro RS
Thank you for the excellent picture. It is very appreciated.
Now to get some line.
The question is what OD is the line?
Car: 92 Camaro RS
Evaporative Emissions Canister Hose Routing
I have a 1992 camaro that was originally had a 305 tbi engine. The car now has a 350 TPI engine. The canister originally had three hose connected to it and one connection blocked off. I don't think this is correct for the TPI engine but am unsure of how to connect it up. Any diagrams or pictures would be great. Thanks.
Glowsock
09-11-2015 11:09 PM
