Ignition lock cylinder help
Old 11-11-2015, 11:26 PM
321FormulaGuy's Avatar
Car: 1990 Pontiac Firebird Formula
Engine: 89 Camaron IROC-Z 350
Ok so I took apart my steering column and replaced my ignition switch, and not realizing it was one the column itself instead of inside I took everything inside apart. I now put everything back together but, now the car won't start and the steering wheel won't unlock. The lock cylinder moves through the sequences with little resistance, with the key in it of course. Unfortunately, there's nothing coming of it when I try to crank the engine. The key just moves basically with no power appearing to go to it.
Any and all help will be greatly appreciated, I need this car running asap as well!
Thank you all ahead of time!
Old 11-11-2015, 11:44 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Ignition lock cylinder help
It's the spring in the ignition switch that gives the resistance. But if the wheel also won't unlock, it's certain that you missed connecting a part in the column. If I recall, there's a gear and rack that actuates the rod up and down, that's where I would look for something amiss.
Old 11-12-2015, 02:14 PM
I believe I forgot to put a part back on the actuator. It's the black plastic piece in the picture.
Attached Thumbnails Ignition lock cylinder help-1447359070166-1929800177.jpg
Old 11-12-2015, 09:53 PM
Anyone have any idea what this part is? I believe this might be one of my issues.
Attached Thumbnails Ignition lock cylinder help-1447386596968-1412738569.jpg   Ignition lock cylinder help-14473866850442143454762.jpg
Old 11-13-2015, 01:34 PM
Got everything back together. I figured out why the key wasn't working, the lock actuator slipped of the rod. But now when I go to start the car the brake light comes on and it won't start and on top of that the fuel pump sounds like it's priming constantly, any help or suggestions will be greatly appreciated!
Old 11-13-2015, 05:31 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
I believe that is what makes your high beams come on. It hooks to a rod and pushes a lever into a switch on your column. It hides behind the plastic cap right behind the turn signal.
As for the starting issue when you took the column apart did you take the two white switches off that were bolted to the top of the column that had metal rods going into them? The longer of the two switches is what tells your car to start and if it is in the wrong position your ca won't start. Also since your car is a 1990 the VATS might be screwing with you if you changed out the cylinder and didn't get the right chipped key.
Old 11-13-2015, 06:10 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Best advice I can give is to search on Youtube for some steering column and/or cylinder lock videos. Most Chevys of the same years will be relatively the same.
KITTClone
11-11-2015 07:58 PM
fonzie85
11-09-2015 08:56 PM
JHutch440
10-26-2015 10:35 PM
bamaboy0323
Wheels and Tires
10-22-2015 08:43 AM
87camaropdg
10-18-2015 09:51 PM
Quick Reply: Ignition lock cylinder help
