need advice
Car: 1982 Z28
Engine: 350 880 block
need advice
Should i go ahead and do the work need to put this 89 harness in my 82 because the 82 harness has bad wires and also the engine going in is setup for TPI.
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: need advice
Seems to me you don't have much choice in the matter. It's either that harness, or, buy a 'new' one.
Re: need advice
No freaking way unless you have a LOT of time on your hands. Almost every wire was cut taking it out. Look at the 20+ wires cut off right behind the bulkhead connector.
I forsee an aftermarket wiring harness in your future. Bring your checkbook.
http://www.painlessperformance.com/webcat/60102
Car: 1982 Z28
Re: need advice
Thanks for the reply. I have nothing but time i can fix those wire's once i fix them can i make the 89 harness work with the 82 Z28 and trash the 82 harness.
Car: 1982 Z28
Re: need advice
so if i use the 89 harness will it work in the 82 what would i have to do to make it work
Car: 87 Iroc 5.7,67 SS Camaro,90 Formula
Engine: 355 AFR Superram LPE 219
Transmission: 700r4 3000 stall 4spd 5 spd
Re: need advice
I hear pocket is the guy to use and very reasonable too.
Chris85z28
LSX and LTX Parts
05-03-2016 10:56 AM
slappahoe2000
02-27-2016 06:47 AM
HP52TA
02-01-2016 02:44 PM
