PTV issues with profiler 195 heads and cc503 cam
Car: 2002 ws6, 2011 sierra 6.2L 6 speed
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
putting L98 back together with profiler 195's, cc503 cam and 1.65 rockers. Ran into major PTV issues on the intake, like .100
Retarded the cam 2* and it has all sorts of clearance now.
Just wondering if maybe the ramp rate of the 1.65's is pushing the valve into the piston a little early or if the offset intake valve of the profilers is just running out of the valve relief a bit on the stock L98 Pistons. Anyone have experience with these heads on an L98?
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
Re: PTV issues with profiler 195 heads and cc503 cam
I've been piecing this car together for so long I forgot that I'm running .015 head gaskets and the heads are shaved .035 lol
Seems odd that 2 deg would make that much of a difference. Are the pistons still .02-.025 in the hole?
And the 1.65's arent going to make huge changes over 1.5's. 0.010-0.015 ish maybe with that cam, you'd have to measure the lift of valve where it contacts the clay, when piston is near tdc during its sweep and divide the difference in rocker ratio
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
Pistons are .025 down yes. The 1.65's add around .050 on the intake.
Total lift wasn't really the issue, I couldn't even get half way through the intake stroke and it would contact. Then I retarded the cam 2 degrees and had all kinds of clearance so it's a valve event issue.
Not sure if comp grinds some advance into the cc503 or not. But perhaps the ramp rate with the 1.65's and shaved heads was just a little too much.
P2V clearance issues happen only in a range of between about 20* before and after TDC between the intake an exhaust stroke AND AT NO OTHER TIME. By the time you're at, say, 45* before or after TDC the piston is sitting more than an inch and a half down the bore. No way there could be contact with the valve at that point.
2* cam change being the difference between actual contact and plenty of clearance? No way.
Perhaps you lined up on the wrong keyway/pointer when you first stabbed it in?
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
No it was definitely on zero.
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
I really should when I have time. So far I just did the old cranking compression test. 160 at -2, 155 at -4
I could try it at zero but would likely end up with zero compression lol
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Def do the degree wheel some timing sets are known to be off QC has gone to hell in the last few yrs
Shouldnt have a PTV issue. Running way more lift (know thats not the end all be all)at one point just under .700 with mucho head shaving and domed pistons .015 down no issue? Something else is going on.
If the timing set cks out id be half temped to stick that cam on a Cam Dr a good machine/head shop will have one it will tell if exactly what that cams doing if somethings off.
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
Yeah it seemed just too advanced.
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
Put my custom chip in, tuned the car and went for a test drive. I had to basically max out my fuel pressure with the 30lb injectors just to get around 14.5:1 AFR AT WOT, then after 5000 it went to 18-19... Dang
Looks like I need need bigger injectors and a pump.
86CamaroDan
04-29-2016 11:25 AM
dpmalibu
04-27-2016 06:23 PM
dpmalibu
04-26-2016 06:32 AM
