Something with my fan
Car: 1986 Camaro IROC-Z
Engine: 350 C.I.
My Camaro will start up normally and run fine until I cut on my fan. I had to hard wire it with a relay. But when I turn it on it gets all choppy and the engine sounds like it's about to cut off.
Car: 1994 Z28
Engine: 355 LT1
Re: Something with my fan
I've tied the ignition box into a "switched" ignition source that ended up being a turn signal. When the turn signal was turned on, it did the same exact thing.
