very rough idle but great at WOT
Old 07-24-2016, 10:23 PM
Dabesiv's Avatar
Car: 1982 Camaro Berlinetta
Engine: GM crate motor Goodwrench 5.7 350
Today I was installing a new A-pillar pod to add a trans temp gauge and swapped my mechanical oil pressure gauge for an electric one. While trying to get the oil pressure sending unit installed I disconnected two spark plug wires from the dizy as well as the two wires for that lead into the dizy for easier access. I replaced the two wires and one plug wire but forgot the other like an idiot.
The car turned over, I backed it off the ramps and noticed the bad idle and had my facepalm moment when I knew what I did. I immediately turned it off and replaced the wire. Now the car is having a very rough idle, like it was when the wire was disconnected, so my first thought is I fouled the plug.
I thought maybe there was a buildup of fuel in the cylinder and that could cause the issue so I took it for a quick ride to try and burn it out. I smashed the pedal and the car launched better than it usually does which I was not expecting, especially if the plug was fouled.
I was due for a plug change anyways so I will probably tackle that later this week, but if that doesn't solve it I have no idea what to do.
Any thoughts on what happened or how I can resolve this?
Old 07-25-2016, 09:47 AM
MSgt Luttrell's Avatar
Car: 1986 IROC Z28
Engine: Carburated small block 454
Transmission: Level 3 Raptor 700R4 2600 stall
Axle/Gears: Strange S60 3:73 S Trac Posi
Re: very rough idle but great at WOT
If it's not a fouled plug, double check to make sure you didn't cross the two wire when you put them back on.
Old 07-25-2016, 11:23 AM
Dabesiv's Avatar
I a 99.99% positive I didnt do that haha I made sure they wouldnt get mixed up but ill check still
Old 07-25-2016, 07:36 PM
Pro
Pro's Avatar
Car: 1992 Z28 and 1995 Silverado
Engine: 5.7 TPI and 5.7 TBI to TPI convert
Transmission: 700R4 and 4l60E
Axle/Gears: G80 3.23 and open 3.42
Broken up carbon keeping the EGR valve open?
Old 07-25-2016, 07:50 PM
skinny z's Avatar
1 8 4 3 6 5 7 2
broke91firebird
09-02-2019 10:02 AM
w41duvernay
Carburetors
03-15-2016 03:54 AM
BP89IROC
Aftermarket Product Review
01-07-2001 07:06 PM
Fastbird
12-29-2000 07:13 AM
theformula
10-11-2000 01:33 PM
Quick Reply: very rough idle but great at WOT
