trying to locate where a vacuum hose goes from evap canister,please help
Old 07-25-2016, 09:11 AM
mikeyt's Avatar
Car: 92 Camaro
Axle/Gears: stock
I've got a 92 rs 305 I've got one of the hoses that goes from the evap canister to the TBI, however I can't figure out where the other one goes to, I've lost the diagram I drew....UGH!!!
Old 07-25-2016, 09:38 AM
MSgt Luttrell's Avatar
Car: 1986 IROC Z28
Engine: Carburated small block 454
Transmission: Level 3 Raptor 700R4 2600 stall
Axle/Gears: Strange S60 3:73 S Trac Posi
Re: trying to locate where a vacuum hose goes from evap canister,please help
Old 07-25-2016, 09:48 AM
mikeyt's Avatar
Car: 92 Camaro
Axle/Gears: stock
Is that diagram for a TBI or does it matter?
Old 07-25-2016, 09:50 AM
Car: 1986 IROC Z28
That should be for the TBI engine and yes, I believe the TPI is different.
Old 07-25-2016, 10:28 AM
mikeyt's Avatar
Car: 92 Camaro
Axle/Gears: stock
I think this is for a TPI unit because my canister is on the driver side
Old 07-25-2016, 11:12 AM
Car: 1986 IROC Z28
Ok, let's try this one.................
Old 07-25-2016, 01:58 PM
mikeyt's Avatar
Car: 92 Camaro
Axle/Gears: stock
PERFECT!!!! Count on the military or prior to come through!!!
Old 07-25-2016, 02:00 PM
Car: 1986 IROC Z28
LOL, glad to help.
Old 07-25-2016, 02:44 PM
mikeyt's Avatar
Car: 92 Camaro
Axle/Gears: stock
I forgot to mention mine is an automatic, is there a difference?
Old 07-25-2016, 02:49 PM
mikeyt's Avatar
Car: 92 Camaro
Axle/Gears: stock
Since I'm using and open element air filter I guess I don't need the IAT sensor and motor, should I be able to just cap that vacuum port off on the TBI unit?
Old 07-25-2016, 05:07 PM
Car: 1986 IROC Z28
I don't see why you couldn't and I don't think there is any difference between a stick and automatic where it comes to the Evap system.
Old 07-25-2016, 09:06 PM
mikeyt's Avatar
Car: 92 Camaro
Axle/Gears: stock
Thank you
Old 07-25-2016, 09:49 PM
Car: 1986 IROC Z28
Anytime Brother, glad to help.
Old 07-25-2016, 10:14 PM
mikeyt's Avatar
Car: 92 Camaro
Axle/Gears: stock
I saw that video of you starting that 383, maybe one day I'll rotate the LO3 out for one of those. Since this is my daughters' first car, it'll be a while-she loves it.
hgen81
11-19-2019 01:06 AM
snakeshooter
05-26-2016 07:32 AM
trevosaursflex
05-24-2016 04:57 PM
Lucky5968
05-22-2016 02:51 PM
IronEagle455
05-17-2016 01:25 PM
Quick Reply: trying to locate where a vacuum hose goes from evap canister,please help
