I need advanced technical knowledge of 90-92 Camaros
#51
Car: 1990 Camaro RS
Engine: 355 Vortec TPI LT4 Hotcam
Transmission: TH700-R4
Re: I need advanced technical knowledge of 90-92 Camaros
Alright guys, got it running again yesterday. Ran good and ran until it got to operating temp. Then after putting the exhaust back on the car, it wouldn't run again. What is going on?! Only thing I did to it yesterday was put my old set of injectors back in it.
#52
Car: 1991 Firebird Formula
Engine: 5.7L TPI
So it still has the old set of injectors in it? And the only change since it was running is putting the exhaust back on? What sort of exhaust do you have? Does it have a catalytic converter? Maybe it's plugged and causing excessive backpressure thus killing the engine? You might try dropping the Y pipe off again and see if it stays running, or maybe as a test before that, check to see how much exhaust you can feel coming out of the tailpipe.
#53
Car: 1990 Camaro RS
The exhaust is all brand new and it's one piece from the headers back to the bumper.
#54
Car: 1990 Camaro RS
Car is at the dealership now, got it to run again but now it keeps shutting off for some reason, and I'm done messing with it.
#55
Engine: 5.7L TPI
Missed your text over the weekend. Hope the dealer can figure something out and get it back to you, looks like it will be a sweet ride when it's up and running.
Bald_eagle_machine
06-20-2016 02:01 PM
gators_bucs_fan
06-09-2016 12:14 PM
