Hazard Switch broke stuck on
Old 08-14-2016, 10:47 PM
ryleeman54's Avatar
I have an 87 Camaro iroc z28 and my hazard light sleeve broke off. It is now stuck on and I do not know how to turn them off. We also need to replace the sleeve. The fuse is pulled out so it will not keep going off.
Old 08-15-2016, 05:59 AM
Received 1,662 Likes on 1,261 Posts
Re: Hazard Switch broke stuck on
You can get up under the dash and push the dimmer switch (on top of the column) to change it from high to low.
There are 2 switches up under there; one is the dimmer sw, the other is the ign sw. The dimmer sw is the MUCH smaller one and only has 3 terminals.
THIRDGEN87
Interior Parts Wanted
08-24-2023 01:01 PM
Kfly67
05-14-2017 08:37 PM
SuziQ305
03-31-2016 08:59 PM
SRKLEGIN
03-27-2016 05:57 PM
liva687
03-16-2016 09:00 AM
Quick Reply: Hazard Switch broke stuck on
