Serpentine pulley questions
Old 09-28-2016, 07:47 PM
grnmachine's Avatar
Car: 92 RS Heritage Edition
Engine: LG4 305
Axle/Gears: 3.73 10 bolt posi
I purchased a serpentine setup awhile back that was missing most of the pulleys I need( crank,water pump and power steering pulleys).I was wondering what other pulleys could be used from other GM cars/trucks besides the ones from the 89-92 F-bodies? The setup came with the A/C and smog pump delete pulleys.I'm also needing the alternator pulley and the bolts/hardware to mount a alternator.
Old 09-28-2016, 10:17 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Serpentine pulley questions
I think just about all 305/350 and 4.3 v6 ~1988-95 will have the correct crank,W/P and P/S pulleys-engines ~96-2000,IIRC,have a thread-on fan clutch and the W/P pulley will be different,but crank and P/S are probably the same.Alternator pulley very common-used on engines mentioned and '84-91 vettes.IIRC,'93-97 LT1 alternator pulley is compatable,but slightly larger diameter than one used on third gen setup.
Old 09-29-2016, 03:53 PM
grnmachine's Avatar
Engine: LG4 305
Thanks for the help.Gonna head to some local u pull it yards this weekend to find what I need.
tapwr
07-20-2017 03:40 PM
94ElBanditoDeCa
02-27-2017 10:35 PM
86NiteRider
11-23-2016 01:29 PM
Brinkkl2000
10-03-2016 11:52 AM
86NiteRider
09-21-2016 08:22 PM
Quick Reply: Serpentine pulley questions
