What would you think this build might cost?
With the following specs starting with nothing but my 88 camaro, I plan to pull the 305 and have something built to about these specs. What would you assume it might cost to build to the specs below turn-key?
Received 1,664 Likes
Re: What would you think this build might cost?
Whatever they quoted you, that's about what it'll cost.
Looks like pretty much the cheeeeeeepest of the cheeeeeeeep. Shouldn't be too terribly $$$$.
I would pass the motor is all procomp stuff. Their quality controll seems less than stellar. I have read a lot of problems with their distributors and head components. Pass.
Not interested in pro comp whatsoever. I'm speaking of a build to these specs with quality components but just to the specs above. Ignore the pro comp references. Please any advice is appreciated. I.e. for the cam say a comp cam and for a crank say a scat crank, etc. Just quality components to the specs above. Thanks
Disaster avoided thanks to all!
bjpotter
09-11-2016 11:14 AM
