Vacuum lines
Vacuum lines
Cars giving me trouble to stay on & I recently found a vacuum that was not connected to anything at all I don't know if this could be causing the problem but it's torn and I want to replace only I don't know where it goes to or what its for. Can someone help me out I really need to get it back to its original condition.
Car: 85 Firebird
Engine: 350 vortec
Transmission: 700R4 2 stage shift kit 2200 stall
Axle/Gears: 3.08
Re: Vacuum lines
What are your vehicle specs?
Try a vacuum diagram search, there are many that are threads on this that should give you a good idea
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Vacuum lines
There's a big black plastic vacuum ball under the partition that the reservoir in the pic is sitting on. Check there
Re: Vacuum lines
I tried fining it and I couldn't unless it doesn't have it but I'm not sure. Can you take a picture not too close so I can see it i looked all morning and did not see one
Re: Vacuum lines
I'm having trouble keeping the car running. I recently switched out the injectors (305 tbi) and I thought it'd fix the problem of it turning off. Gas gets to them but as soon as I step on the gas to rev it, the car bogs and dies immediately then I have trouble starting it. Any ideas what it could be ? I'm thinking it might be an ignition problem I checked out the whole fuel system and it seems to be doing fine
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Vacuum lines
Have you tried this?
https://www.thirdgen.org/tpimod2/
Came fro the how-Tos section above. Lots of good info in there
Re: Vacuum lines
Did you ever find the cannonball?
The 1992 Camaro is equipped with a cannonball -- otherwise known as the vacuum reservoir.
See http://www.rockauto.com/en/catalog/c...reservoir,5177
and
http://www.rockauto.com/en/moreinfo....=1035818&jsn=8
I guarantee your car won't run right if the vacuum line that connects to that reservoir is not connected to the reservoir. Without that connection, the intake is just sucking random air into it constantly. Your fuel/air ratio will never be right until you fix that.
The vapor recovery cannister sits on top of a sheet metal shelf under your hood. You can see the vapor recovery cannister easily. The cannonball is bolted to the UNDER side of that shelf, and you cannot see it unless you crawl under the car. The cannonball cannot be seen from above.
and
Re: Vacuum lines
Checked the ball and found no line connected to it. There a was a small piece on it aso if the line tore off. What line goes connected to it ? Does anyone know
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Vacuum lines
Here's an old thread that has some diagrams that may help. Can't tell, some of your vacuum lines look different than mine. Does your cruise control work? Anyway, check these out
https://www.thirdgen.org/forums/tech...ol-vacuum.html
Have fun!
Have fun!
Re: Vacuum lines
And honestly I don't know if it does I have not been able to fully run the car. There's not many diagrams on the 305s so it's difficult to find one that tells me where these hoses go
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Vacuum lines
what happens when the car is running and you block off the end of that hose with your finger? Will it run that long? Otherwise plug it and see how it runs
Check the thread I gave you a link to in post 17 above. Can you follow the hose from by the distributor to the ball?
Re: Vacuum lines
I may have not mentioned the car say for 8 years. I've already changed many parts out and installed new ones. I have yet to touch the distributor though which may be ****
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Vacuum lines
Ah, have you drained all of that used-to-be usable gas and replaced it with newer fuel? I think you have much more than a vacuum leak problem. At least it tries to run, that's kind of a good sign
Re: Vacuum lines
Yeah I installed a new tank and pump got out all the bad fuel, new hoses and radiator, new fuel filter oil filter water pump and injectors tps iac all of it. But I have not touched the dizzy also new plugs
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Vacuum lines
Since it tries to run the distributor is probably OK unless the ignition module has a problem, but sitting shouldn't have hurt it. Did you clean out and rebuild the throttle body when you replaced the injectors? Like check the diaphragm in the fuel pressure regulator?
Re: Vacuum lines
I'm beginning to think it's an ignition problem and not a fuel, I've had some backfire through the manifold and I don't know why. One guy told me the timing could be off but I wouldn't know much about that, the car was running for a short time but it wasn't until I attempted to drive it that I noticed I couldn't surpass 3000 rpm and now it barely stays on
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Vacuum lines
Is the distributor loose or has it been moved at all?. Might as well take out the ignition module and haul it down to Autozone and get it tested. If you do, have them test it two or three times if they will. It needs to heat up sometimes to start to fail. They'll do it for free. Maybe it has gotten corroded in there and damaged the grounding ability of the unit? Definitely worth a look
Re: Vacuum lines
Well that's what my next move is then, I really appreciate the help, it's been an on going problem and I want the car to run. I'll let you know what I find and the results!
Car: 1984 Z28
Engine: LG4 305/4bbl for now
Transmission: 5-Speed
Axle/Gears: 3.23 Posi
Re: Vacuum lines
There should be an "Oil pressure switch" at the back of your block near the distributor, if its bad, or unplugged, it will prime the pump, long enough for you to start the engine and then the computer is waiting on some sort of engine oil pressure signal from that switch to keep the fuel pump running. Had this issue on a C4 Corvette, drove me nuts!
Last edited by 1987L69; 10-27-2016 at 12:22 PM. Reason: changed "Fuel pressure" to Oil pressure
Re: Vacuum lines
Would the fuel pump relay cause the vehicle to do what it's doing. I think the pump doesn't get enough power when the vehicle starts it does prime but I believe once the vehicle is on it stop pumping as much
