codes-13,23,24
Car: 1986 Camaro IROC-Z
Engine: 350 swap
Transmission: manual
codes-13,23,24
Hi,
I recently swap my 305 for a crate 350 with Holley carburetor 670 and headers (done by mechanic) After getting my service engine to work, I am getting codes 13, 23, and 24. Apparently code 13 indicates something with the O2 sensors, 23 with M/C solenoid, and 24 with the speed sensor.
My main questions are related to codes 13 and 23.
1- is the O2 sensor gone usually when headers are installed, or is the sensor usually replace somewhere in the header? I can always the mechanic....
2- is the solenoid now replace by an intake air temperature sensor, or the solenoid still exist in the carburetor?
Any suggestion in where to start with this journey is appreciated.
Engine: 350 swap
Re: codes-13,23,24
Sorry to ask again, but do you know of a ECM set up that I could install that would be able to scan for codes?
See, I am not much of mechanic, but work in my car for simple thing. It is always nice to have code to have some idea what I am getting into.
Thanks in advanced!
Thanks in advanced!
Re: codes-13,23,24
http://www.winaldl.joby.se
It's a waste of funds to even purchase anything since your car is no longer computer controlled.
