Air/Cleaner Filter option
Car: !982 Trans Am
Transmission: 350 Turbo
Axle/Gears: 3.08
I'm running a 350 in a 85 T/A with 82-84 hood. Also running a Quick fuel carb with electric choke. What are my air filter options? Can I run a regular 14" with 2" filter or do I need a drop base style? Any input would be helpful.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Re: Air/Cleaner Filter option
With the typical 1-1/2" drop base, you can run a 14"x3" air filter.
Unless your intake manifold is particularly tall, or you're running a carb spacer or adapter.
