Firebird Flasher Location....?
Old 01-15-2002, 05:09 PM
Steve R's Avatar
Where is the turn signal flasher in a '89 GTA?
Old 01-15-2002, 09:30 PM
Vader's Avatar
Steve,
The flasher you might have found while looking at the swingout Convenience Center panel would be the hazard flasher. Note the silver can:
The flasher for the turn signals is tucked up under the dash in the driver's footwell area. GM engineers must have had a ball playing "hide the component" with this item. There is a steel spring clip affixed to the lower edge of the dash panel. You'll have to remove the lower trim panels and covers for the HVAC ductwork. Reach backward at the lower edge and you should be able to feel it, or look with a good light and a mirror to view it. Are we having fun yet?
Old 01-15-2002, 11:13 PM
Steve R's Avatar
... so if i'm kneeling on the ground, looking at the dash, would it be on the left or right side? And would it be near the gauges, or near the firewall?
It's a mess in there because someone installed an alarm and did a bad hack job.
thanks!
Old 01-17-2002, 04:55 PM
Steve R's Avatar
btt...
Old 01-17-2002, 05:53 PM
Drew's Avatar
Received 1,052 Likes on 748 Posts
From your drivers seat, the convenience center is on the right, the fuses are on the left.
Old 01-18-2002, 09:25 AM
Gta-Paladin's Avatar
And i had a fun time trying to put a fuse in.. I think i was sitting in my drivers seat upsidown because it was so akward.
64goatman
09-09-2015 01:09 PM
jtwoods4
09-03-2015 05:39 PM
Formula_88AE
09-03-2015 01:47 PM
jtwoods4
09-03-2015 10:19 AM
1Aauto
Sponsored Vendors
09-02-2015 01:35 PM
Quick Reply: Firebird Flasher Location....?
