are our cars meant to be run hard?
I have a new engine in my iroc and it has about 10 thousand miles on it and i have ran about 2000 of those miles hard. I was wondering what effect this does on my engine.
Car: No more birdy
What kind of hard are you talking about?
Any abuse on anything will cause premature failure. An engine can be built to handle a degree of abuse like a race engine but even the builder knows its eventually going to fall apart. People who drag race pray an engine lasts a season but its not a huge supprise when it grenades at the track.
Only abuse an engine when there is a good reason and it will last a long time.
SSC
SSC
what you mean by "hard" probably isnt anything that crazy...unless your revving to like 6k and arent dropping it in drive at 5000rpm or crazy **** like that you should be alright
1 Post
Car: 99 Formula
Axle/Gears: 342
What would be the point of having a fast car if you don't run it hard. Then again, I remember a quote from someone, "It's not about going fast all the time, it's knowing I can go fast when I want" or something like that. Never taking it above 4500 rpms doesn't seem to be rough at all. I hear babying the engine can be just as bad.
What are you asking about? Your new engine being driven hard? Or our whatever decade old engines?
When they our cars first came out, Yes they were to be driven hard, they were made to handle it. I'm sure if you broke your new engine in for atleast 1000 miles, I'm sure now you can rip rip. But today our (old) engines are old. Don't drive them too hard, just a couple heres and theres, unless ya don't cares. Hehe.
haha yeah I know its the same block and heads, but just a complete rebuild. I'm sure I will be fine I was just wondering how bad it is on the rings, but I guess I'll be fine then. I havent had this engine over 5 grand yet.
Well, assuming you kept your foot out of it for the first couple thousand miles, you should be fine. I wouldn't go flooring it as soon as you turn it on in the morning, but once your oil is warm, let it rip. But driving hard is hard on more than the motor. Your transmission will go sooner and your suspension parts will wear out faster.
yeah I dont floor it oranything in the morning. Its just a friend of mine now has a 97 camaro z28 special edition lt4. Well I can keep up with him, but its running my car kinda hard. I have it at like 3/4 throttle. I dont floor it like spinning the tires, but ya know what I mean. I should be fine now I guess im just mainly using a lot of gas...lol
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
piston motors can be driven hard but you will put a lot of wear on the motor. think about it. your pistons move back and forth in a very nasty motion which is going to put stress on the crank,rods,piston and dont forget the valvtrain also doing the same thing with your valvesprings ,lifters and so forth.
those parts will start to wear out very quick if you keep reving it up high all the time.
now once every now and then prolly will not do all that much damage but keep it up all the time and your motor is not going to like you.
also since you are making the speed of all the parts go up on top of just the force from the back and forth movement you are going to have a higher wear. on the block and all those other moving parts..
then there is lucky me
I take my motor up to 7000-8000 almost everyday with 171k on motor (well will be soon once I put that motor back in)
I admit I rev it a lot more then I prolly should but so far no problems.
also helps keep the carbon build up out of my seals which will kill my power.
baby this thing is bad... more carbon... not good.... so I am very rev happy
after i finally fixed my car me and some friends in my car drove about 45 miles on the interstate with a buddy following in a 92 grand am (lol) well anyways i gave it hell the whole way dont think i ever went under 100 and my buddy tried to keep up...it only took like 15 minutes or alittle more to make it back and i swear after that the car ran better...it was babied its whole life until i got it...it was a car that was driven by a 30 year old women back and forth to the store until it started having problems (fuel pump) then it was garaged for 9 months
Car: 88 GTA
Well after beating the living snot out of my car for 2 years it died, before i bought it, a 50 year old lady drove it easy, then the car went to hell and back.
Dave
Dave
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Lol... Beating an engine is not good... Beat teh ****ing **** outta my tahoe i bought as a beater (not too bad when i got it) and now 6 months later the engine has a rod knock and a beat trans. Too many WOT starts and peeling out
Mutillator
Exterior Parts for Sale
10-01-2015 06:05 PM
