Buick GN vs 383 Formula
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
Just had a quick run with a friends 87 Grand National. He showed up on slicks and running race fuel. It's a bolt on car, stock internals and stock turbo with 6 extra pounds of boost. We went from a dead stop, both heated our tires for 3-4 seconds. I have to say the G bodies hook nice, really plant the rear. He didn't spin at all on the slicks. My MT DRs felt like I was on ice, spun really bad. My converter flashing to 4400 is a bit to much. Anyway he had 2 1/2 cars on me right away. Of course I bounced the rev limited off the 1-2 shift(6400) and again the 2-3 shift(I was a mess). By the 1/8 mile I was pulling him, he was a car a head. Then I pulled him in just before the end of the 1/4. May have learned a few things tonight. Next time I'll let the car shift itself..lol. I'll also see if I can get him to run from a slow roll if he has the slicks/race fuel again.
Car: 1994 Z28
Engine: 355 LT1
Re: Buick GN vs 383 Formula
GN is an easy mid 12 second setup. Local guy runs water meth with bolt ons and turns low 12's on radials.
1 Post
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
Close call! As stated, the GN should be a mid - low 12 sec car. Man those things respond really well to simple mods!
One of these days I will own another one... sigh
Car: 1994 Z28
Engine: 355 LT1
Got one in my garage... read up on a tune only for premium fuel, multiple claims of something like 30hp and like 90 ft lbs.
Originally Posted by TPI-Formula350-
I'll also see if I can get him to run from a slow roll if he has the slicks/race fuel again...
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
That is the awesomeness of a turbo motor - lots of power and TQ with relative ease of adding more. When you consider the 3.8L motor was more a large V6 for mid and full size cars, never making 200hp NA in any form, the power of the GN is all that more impressive.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
You are over powering the radials big time, VS his power coming in smoother. At the track slick for slick you should murder.
Car: 89 Formula 350
I really need to figure out how to make the car hook better from the stop. I have MT DRs, Founders LCAs, and UMI LCARBs...The stall is an off the shelf Hughes 3000 converter but it's flashing to 4400. So with that converter and the engine making 517 fwtq the tires just smoke even after heating.
Any ideas on getting the car to hook better?? I'm looking to get a cross member mounted adjustable torque arm. I'm not really into the drag shocks.
stock turbo with 6 extra pounds of boost...
Car: 89 Formula 350
Didn't see this part, and I find this pretty amazing that he had that much of a jump and lead on you at only six pounds of boost pressure. Why was he running such low boost, was it agreed before the run? Stock turbo is good for up to 15 pounds of boost before it starts heating up the charge, is he down an alky system and FMIC as a reason for keeping boost pressure low? From the sound of it, at 15-psi you won't be able to catch him whether from a dig or a roll...
read it again "6 extra pounds of boost" above the stock boost.... 15 pounds plus the extra 6 pounds = 21 pounds of boost
read it again "6 extra pounds of boost" above the stock boost.... 15 pounds plus the extra 6 pounds = 21 pounds of boost...
Car: 89 Formula 350
there is no BS, if any thing a misunderstanding. I'm not a turbo guy, I have no idea how much boost a GN was set to from the factory. The reason I said from the start " 6 extra pounds of boost" is because he told me he was 6 pounds over the factory boost setting.
I just added that number to what you said the factory turbo was good for. So you tell me whats stock boost for a GN and add 6 more pounds of boost and that. he was running on bolton, slicks and race fuel.
Car: 1994 Z28
Engine: 355 LT1
I'm pretty sure they only reach about 12 PSI from the factory. Have a low mileage bone stock one in the garage and I've never seen it go anywhere near 15 PSI.
Don't have to read it again because you didn't say six pounds over what it is tuned for. Grand Nationals didn't come from the factory set to 15-psi, I said they were tuned for up to 15-psi, GM didn't need the owners killing themselves as they drove off the lot. LC2's are something that I am very familiar with being that I have owned a few of them, and part of the reason why I asked to see video I guess. At 21-psi, a "bolt on" (as per you) Grand National with stock turbo can and will see mid elevens, and there is no way you are catching that at the end of the quarter with that much of a lead from the getgo. Gotta call BS on this one to tell you the truth...
But anyway, the race sounds legit. I would never count a car out even with a two car lead.
Car: 89 Formula 350
Street - there is a video taken from about the 1/8. In the video he is a car ahead of me, before I pulled him down...I'll see if I can get it..its a night time video so not the best quality.
Car: 1994 Z28
Engine: 355 LT1
ok, so like I said he was running 6 pounds over the stock boost. 12+6=18 pounds of boost.
My goodness, let me clarify something. I am not here to pull the "BS" flag without a good reason. I can assure you that in the Grand National world, Ed Brewer ran 11.37 with the stock heads, stock LC2 camshaft (192/196 .384"/.408" (w/1.55 rockers) @ 107 LSA), and the stock turbo. A camshaft like that isn't going to have great top end, but there are plenty of grinds that do though. It doesn't take much for the LC2 to dive into the elevens with the stock turbo, as members have been doing it with less than 400-RWHP. To analyze what was said above, we have a Grand National w/bolt on's and slicks running 21-psi. This would tell anyone that already owned a Grand National that the owner was ready to run because a Grand National "should" hookup fine running the stock turbo without the slicks, yet he felt compelled to run them, which tells me he launched hard. Not to mention, nobody would run 21-psi with the stock turbo without 93 octane and alky injection, or C16 for that matter, because above 15-psi the stock turbo will essentially cause detonation from the heated charge, and when we get into boost, every pound of boost above 15-psi is very substantial in terms of horsepower being added...
Car: 89 Formula 350
I don't doubt you can run him down. These cars are not known for top end power. His final drive ratio is a tad bit lower (numerically) than yours and I doubt he's making the same horsepower. However, as you sat you lost the race. You stated it yourself, the g-body suspension hooks very well.
Car: 89 Formula 350
I know there are a lot of GNs in the 11s with little mods..This car has few boltons ,slicks,Cam2 race fuel, and 6 extra pounds of boost..This GN is not in the 11s and I never said it was.
Stock boost on an intercooled GN is 13 PSI, +6 = 19 PSI. 19 PSI on a stock turbo will run you around 350 FWHP. If it really is a stock turbo, it could be a mid-12 second car on a good day. If you have 467 FWHP, catching him by the end of the 1/4 should be about right. A stock turbo would need to be running 25-30 PSI to be near your HP level.
Bigger turbos are considered "bolt-ons." Unless you know FOR SURE the size of the turbo on that GN (several of them look stock) you can't be sure what you're racing. You can never tell what a GN will run until you've ran it, 10-second GN's look and sound much like 14 second GN's.
Originally Posted by Copperhead
Stock boost on an intercooled GN is 13 PSI, +6 = 19 PSI. 19 PSI on a stock turbo will run you around 350 FWHP. If it really is a stock turbo, it could be a mid-12 second car on a good day. If you have 467 FWHP, catching him by the end of the 1/4 should be about right. A stock turbo would need to be running 25-30 PSI to be near your HP level...
Car: 89 Formula 350
Poor quality video made from 1/8 or about 7 seconds into run. At this point he was a car a head. I don't have any video from the end of the 1/4 but had him by then.
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
GN isn't that great, same with the TTA.
Remember there is no replacement for displacement
Originally Posted by rx7speed
GN isn't that great, same with the TTA...
Back to the topic though, I remember when this one was sold way back when, it sported a stock turbo and psi was upped to over 20+. Even the guy who uploaded the video doesn't remember the details regarding the upgrades, but I do remember that this TTA was running the stock turbo, block and heads at the time it was sold. The rate of acceleration with these little motors is unreal, and the Buick guys have it down to a science...
Car: 1991 Camaro RS
Engine: BBC 509 Merlin ii 9.6:1 pump gas
Transmission: ATI pro th350 sfi case. TSI 5500 st
Axle/Gears: Strange S60 4:10s
I've only had the priviledge to race one GN before and I know I was no competition at all considering he car was not far from stock. I went 13.50's to his 12.40s(IIRC) and he didnt do much to the car but jack the boost a little.
The T-type, GN, and TTA's are truely amazing cars produced in the 80's!!
You would have murdered him from a roll. Get some better footage next time!! Cool race though, I'd be honored to run one of those unicorns.
Car: 89 Formula 350
Hey Street - spoke to the GN guy today and asked him how much boost he was running when we raced. He just told me 21 pounds, I'll find out his other mods Saturday, He's my auto body shop guy and I have to drop my car off for new door hinge pins then. I told him you turbo guys online were saying that was good for low 11's, he said he is slower then that. So as of now all I know for sure is he had slicks, Cam 2 race fuel and 21 pounds of boost. I'll ask him about his bolt on but I don't think many. I'm not looking to BS anyone so I'll just tell you guys what he tells me.
edit..spoke to GN guy... 21 pounds of boost, larger down pipe, MT STREET slicks, 116 octane race fuel.
Car: 1994 Z28
Engine: 355 LT1
Nope... only ever owned a 454 punched .040" with oval ports and a mildly built vortec 350 with a 100 shot in a SCSB S10. Doubt either of them even broke 300 crank horses.
Engine: 4++,350 & 305 CIs
I totally agree, my DRs were useless. When I suggested going from a roll next he wanted nothing to do with that idea. I'm sure he was surprised I caught him after him putting cars on me out of the hole. I'm sure I would have put 5-6 cars on him from a roll. I was still happy to catch him at the top of the 1/4.
Car: 1992 B4C
Engine: L98 5.7 liter
Transmission: THM 700-R4
Racing from a roll also takes the science of launch and traction out of the equasion.
Its more a means of racing for those that dont know what throttle control is.
My Fox Mustang (383W/PT78 turbo)made 500WHP at 6.5 psi, now up to 11 psi (not dyno'd since) but figure thats over 600 at the tires in a #3000 car. .... and like a GN, (wish I still had mine) can be as docile as it needs to be, or be as much of a hooligan you want it to be.... all based on your right foot.
Thats the beauty of turbocharging...
Now... if the Mustang still had AC... LOL
Car: 89 Formula 350
The lcas are angled slightly down towards the back of the car, installed in the bottom hole of the relocation brackets. I need an adjustable tq arm next. I won't remove the front sway bar because I won't sacrifice handling.
These guys are so homo, I'm sure they wish they had a bored over 454:
If you want to bang out some hard cornering put it on.
I take mine off an put it on all the time, depending what I wana do with the car that day.
Car: 1992 B4C
Not too much science for launching/traction: slicks, stalled, geared with some suspension mods. However, not everyone likes to drive on the streets with slicks, etc. Also, there are less chances of getting busted when you don't risk stopping, prepping street, warming up the tires, and having someone flag a street race.
Geometry for the lower arms is key (and a science the g-body guys have gotten down pat. F-bodys have to deal with torque arm (trans mount) failures. All can be overcome, but most dont want to put the time into thier cars to make them launch right.
Slicks?... try DRs with proper air pressure. A well built car on DRs will do fine, considering its built for it and the driver can drive with DRs.
Once you dial in suspension.. the biggest problem is the loose nut behind the steering wheel. Make a drag car a drift car at the touch of the throttle.
It takes far more skill to know how to let off rather than to hold it to the floor.
Interesting though... you post a video of on a roll racing.. and the guy in the firechicken has DRs (or maybe slicks) and he held with the car next to him.
#42
Car: 1989 Trans Am WS6
Engine: SBC+TPI+BOOST
Axle/Gears: Eaton 373
How old are you bro? Because it seems like you just tuned into the whole performance car thing about 2 weeks ago. No offense but I keep seeing youre posts and..... well. IDK...
Eric. Keep up the great work Bro. You know I love reading these threads with one of my favorite Thirdgens of all time.
#43
Car: 1994 Z28
Engine: 355 LT1
Cool youtube video bro.
I've stated it many times before, I don't consider a car that traps a higher speed with a slower ET to be faster than a car that turns a faster ET with a slower speed. Your car is a total package, not just a motor. It isn't my fault that you dumped all your money into your motor and forgot about your suspension. No need to get all bitter
Edit:
And I forgot about all the science that goes into building a motor... stupid me! Any moron with half a brain can assemble a motor using expensive aftermarket parts and make big power numbers. What separates the morons from everybody else is ridiculously high trap speeds with terrible ETs.
Edit:
#45
Edit:
Edit:
Yes that easy...When you see a stock suspension f-body pull 1.6's on stock suspension, I consider it pretty easy
#46
Car: 1994 Z28
Engine: 355 LT1
I see what you are saying but some people like street cars and not high stalled, DR/ET Slick car with skinnies with powerglides in their cars. Maybe I'm just jealous because my 6 speed will never be as fast as a stalled auto from a dig but from a roll...you get the idea.
It's almost like at what point is sacrificing low end torque for top end power on the street.
The only true way to race in my eyes is from a dead stop. Just like you have edge when it comes to running from a roll (and ultimately less drive train loss), it is only fair to give the other car their advantage as well; which more than likely leaves you chasing and relying on top end to run them down anyway.
#47
Car: 2005 BMW 545i
Engine: 4.4L N62B44
[QUOTE=Street Lethal;5382639]Of course not, their 3.8's are no match for the Century 3.1's... QUOTE]
Yup if I put a 3.4 in my car it would be mad fast cause it has more displacement.
#48
I agree. At least someone gets it.
How old are you? Did you just discover the internet gramps?
#49
Car: 1991 Camaro RS
[quote=rx7speed;5384815]oh yeah but if that 3.8 had a 305 in it we all know it would make more power. ie there is no replacement for dispacement
I still dissagree. The only replacement for displacement is who has the most $$ and knowldege in a specific engine. BOOST
