if you just bought your first thirdgen READ THIS
#151
1 Post
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: if you just bought your first thirdgen READ THIS
Like I said not sure where you got your information.
I built a TBI 350, ported the stock swirl ports, dropped in a LT1 cam, and made 279 RWHP AND had so much more torque than a LT1. In my heavy old G-van it ran in the mid 15s. It would have dropped right in place of a 305 TBI and pushed even the heaviest open differential thirdgen well into the 13s.
#152
1 Post
Axle/Gears: 3:42
I have seen healthy 350 TPI's with the better TPI heads and stock cam which is like an Lt1 cam make only 200 hp at the wheel sometimes. What kind of Tbi 350 did you use?
#153
Car: 1983 G20 Chevy
Transmission: 4L60
TBI heads are BETTER than the TPI IMO for what we are using them for, especially after porting.
My weak little 305 TBI with a custom chip, high flow cat, and flowmaster muffler was 178/261 to the tires and I had much more drivetrain loss than a thirdgen. The same engine, save for flattop pistons, ported 305 vortecs, 1.6:1 roller rockers, and adjustable timing set to retard the factory peanut roller cam 4* made over 240 RWHP.
I dyno'd a stock stock 350 TBI crate engine for a 1-ton with its sickly 8.75:1 compression ratio and it made 176/261 to the tires with the stock chip. Only changes were the pellet box cat gone and running the 1/2 ton tuning.
#154
Car: 1983 G20 Chevy
Transmission: 4L60
The same engine with a LT4 production cam, edelbrock 3704 intake, 1" open center TBI spacer, upgraded valve springs, 1.6:1 full roller rockers and a set of doug thorley tri-y headers into a single 3" exhaust made 236/287 on the stock tuning. When tuned it made 253/327 to the tires, this was with the stock compression ratio and stock swirl ports. The same exact engine made 323/327 to the wheels with Vortecs ported/milled/2.05-1.60 valves installed and an edelbrock performer RPM intake with Big Block TBI. Same setup with a custom grind Reed cam and Edelbrock 2bbl victor Jr intake made 365/382 to the wheels. It pushed a heavy G-van to a 14.1 @ 99 with a 3.08 gear and stock stalled 4L60E. I later built a 10.5:1 383 setup using the same cam and modified vortecs, heavy port work on an edelbrock 3817 TPI/Vortec base, siamesed SLP runners, ported plenum, stock TPI throttle body and put down 370/433 TQ. At that point I could no longer keep a 4L60E in it. The complete setup is still parked in the G-van, parked in my driveway. About to get pulled out and put into a 1989 SWB S10. It is poop brown, aka V8 Turd.
#155
Car: 1983 G20 Chevy
Transmission: 4L60
It is not nearly as hard to make power as you make it out to be. With minimal changes I have a truck that started life running 14.7s @ 92-93 mph and now runs 0-100 in 13.6s. It does not have slicks, no weight reduction, never had the valve covers off, has stock intake and exhaust manifolds, and still has 2 of the factory catalytic converters in place.
#156
1 Post
Axle/Gears: 3:42
Your numbers don't make sense either. I have seen a bone stock Corvette with manual transmission make nearly 230 RWHP on a SD TPI 350 that was rated at 250 hp. Saw a stock SD TPI 305 make right at 200 RWHP as well.
#158
Car: 1983 G20 Chevy
Transmission: 4L60
I realize that, with wheezy stock exhaust manifolds, tiny restricted Y-pipe, oem air cleaner, crappy stock tune that was too retarded and too much fuel. Also have to remember the engines are NET rated with all the accessories installed and operating.
My second 305 did not start life as a TBI but a Vortec block. It was a .030" over block with flattop pistons and 1/2 point higher compression than a TBI. It did have a stock L03 cam, 1.6:1 full roller rockers, and stock L03 heads on it. Used a stock 350 TBI intake manifold from a 1992 Van and matching 2 1/4" outlet log manifolds into a factory 92' van Y-pipe. The factory pellet box cat was removed for a single 3" random tech cat and the factory muffler replaced with a Flowmaster 40 series single in/dual out into 2 1/4" tail pipes. I ran 16.1 @ 85 mph in the 1/4 with this setup in a 5,300 lbs G-van.
#159
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
why did i waste the time reading this whole thing? its weird i just felt compelled to keep going i know both my thirdgens so far have been slow lol the v6 definitely felt way faster, then again the carb'd 305 is heavier and not that much faster the way it ran (like ****) when it ran, but that sure didn't stop me from going out and having fun in it, especially in ice or snow and i only lost in the z28 to a bolt on/exhaust 97 z28 but then again i expected too, and i didn't break my serp belt racing (he did, i have v belts too) thirdgens were great in their heyday, now they're the best form of cheap fun cars with potential
#160
1 Post
Car: 1991 firebird GTA
Engine: 305 tpi
Transmission: 5spd
Axle/Gears: 3.42 posi
I just boughtz a newz 92 gtazzz with 305z and 5spdzz can i haz a race nowz?!!?
#161
Car: 1988 firebird formula 350
Axle/Gears: 2.77
but dont expect to beat anything but civics,altimas,and v6 mustangs
Posted from Thirdgen.org App for Android
#164
Axle/Gears: 2.77
reading the raging responses makes the work day go by
#165
My bolt on L98 hung with ls1 cars that were stockish and also Lt1 cars. It ran low 13's most of the time. My stock ls1 car went 13.4 but an auto 2.73 car, not quite as quick as manuals. But for an old car the L98 was pretty quick. That was 10 yrs ago.
Today things are much faster. 10-12 sec cars stock from factory and family cars goin 14's.
#166
Car: 1994 Z28
Engine: 355 LT1
#167
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
While I have seen some pretty knarly build big CI LT1s, there have been a lot of dogs done too by my friends - especially those mostly stock ones with paxton/vortech superchargers that either blew up or had to be insanely abused to get anything resembling good 1/4 mile numbers in them.
#168
I have seen stock internal L98's with procharger kits turn 114-115 mph traps which is good for high 11's with traction. Lt1's with boost should easily do that and more. Thats not really a dog but for the money you can go faster with cam heads and spray
#170
Runs rough and dies after about 10/15 secs 3.1 v6 92 25th anniversary RS
A. if you have any motor besides an l98, do not race anything! 305 cars are the reason people think hondas are fast.
B. if you have an l98, you can race hondas and minivans. but you are still very slow and you will get beat by v6 muskrats.
C. if you own a 305 car, do NOT go to the track and race. you will only be upset by a pocketfull of 16sec timeslips.
D. if you insist on racing you stockish thirdgen, pick your battles carefully, dnt ever think you are about to win. but if you tree hard and launch right a stock l98 will hang with alot newer cars to about 80.
E. have fun, be safe, go race.
#171
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
Re: Runs rough and dies after about 10/15 secs 3.1 v6 92 25th anniversary RS
My 25th anniversary 92 RS Camaro idles rough ! When u give it some throttle it dies ! Have replaced all sensors except knock sensor ! Replaced fuel pump filter sock fuel regulator diaphram plugs wires fuses relays distributor cap rotor ! Could this be as simple as a bad fuel injector or a ground problem ? Oh yes I have put a new ECM in this thing also ! Any help would be greatly appeeciated
#175
Transmission: 5spd
Guys maybe I'm being a dick here but this is absolutely the wrong place to be discussing this. Mods can you move this to the appropriate section?
#177
Would if I could figure it out ! Site is not so user friendly ! And I'm just your average hillbilly joe ! So just bare with me please ?
#178
Transmission: 5spd
not trying to be a jerk. but the separate boards are moderated by the most knowledgeable people in that section. post you problem there and they should easily be able to help you.
#179
Car: 1991 Z/28 1LE
Engine: 305 5.0 LB9
Transmission: T5 World-Class
Axle/Gears: G92 3.42
A 305 is the reason people think 6 cylinders are fast? No, I've eaten so many 5.0's(old) and 2003ish gt's alive in my 1LE
Maybe you think they're slow because you have those old lady 2.77 gears your car would move faster than a Wells Fargo carriage.
And in my 305(damn near stock) I pulled a high 13 last week and pull low 14's on a regular basis
EDIT: and you make it sound so difficult to get power out of a chevy small block, I don't know why....
#180
86IROC112
09-07-2015 01:37 PM
