Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
HP Estimate
Old 09-03-2016, 02:57 PM
WASyL's Avatar
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
HP Estimate
What numbeers should i expect? Dyno within a month. Here is engine spec.
305 with 030 overbore
LT1 intake manifold fully ported
Stock LT1 heads 2.0/1.55 valves, milled up to valve seats
Long headers
Flat tapped cam 235/240 .490/.490 lsa 112 advanced 2 deg
Pumpgas
WOT@13.0:1 AFR
2x51 TB
Best regards
Old 09-06-2016, 12:51 PM
skinny z's Avatar
Re: HP Estimate
1.1 - 1.2 HP/CI at the crank provided your compression ratio matches the cam.
Just a guess....
Old 09-06-2016, 03:12 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: HP Estimate
i didnt think a 305 bore would accept that size valve?
" milled up to valve seats" better check valve to piston clearance. sounds like a high compression build. i'm curious to see how much power it makes.
Old 09-06-2016, 03:15 PM
WASyL's Avatar
Re: HP Estimate
305 wont but with 030 over will, but valve lift is limited to 500
That 1.1 1.2 per ci is what i look for
best regards
Old 09-06-2016, 03:28 PM
skinny z's Avatar
Re: HP Estimate
It'll take some RPMs to get there. I would think that cam in a 305 would peak past 6000. Possibly 6500 provided the heads can support it. I don't have any direct experience with the LT1 head but if memory serves, the L31 Vortec is based off of the LT1 intake port. That counts for something.
camaro1185
03-22-2016 06:41 AM
neruve
LSX and LTX Parts
03-16-2016 02:17 PM
Scorched1984
03-13-2016 10:10 AM
camarojoe
Aftermarket Product Review
11-17-2000 02:20 AM
Gary89RS
10-18-2000 01:45 PM
Quick Reply: HP Estimate
