What kind of power would this make with this setup???
I have a 515 lift 300 duration cam kit with a summit stage 4 intake with a Holley 750 DBL pumper going in a 350 .60 over with vortec 062 heads ported and polished...
Car: 1984 Z28
Engine: LG4 305/4bbl for now
Transmission: 5-Speed
Axle/Gears: 3.23 Posi
Re: What kind of power would this make with this setup???
What exhaust will you be running? it's not so much how big the cam is, but will everything work together, what compression are you running? I would say the intake and heads will be the limiting factors, but I would guess with a good exhaust system, you are looking at 350-370 flywheel HP
