Removal OF EGR
Old 03-05-2003, 09:28 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Removal OF EGR
Hey all I am in the process of replacing my LB9 (auto) cam with the LT4 cam and my EGR is bad. Can I just do away with it since I do not have any smog test in my area? What is the down side of doing this?
Brian Felts
Old 03-06-2003, 12:11 AM
vortech305's Avatar
Well the purpose of an EGR is to recycle the exhaust into the intake too cool the combustion lowering Nox. This off course only happens at WOT and not at idle. Its really not gonna affect anything if u delete it. I believe u will get a code.
Old 03-06-2003, 02:13 PM
BTT any other opinions????
Brian Felts
Old 03-06-2003, 03:59 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
If you want to get rid of it, you should disable it in the ECM. 2 second fix in the PROM.
BTW, EGR is not active at WOT, it's active only at cruise throttle levels.
GeneralIesrussi
Carburetors
01-20-2020 01:06 PM
MY87LT
Aftermarket Product Review
06-07-2016 09:47 PM
Fronzizzle
09-08-2015 12:10 PM
Stryker412
09-07-2015 09:11 AM
rjcme
09-05-2015 01:23 PM
Quick Reply: Removal OF EGR
