What does the tranny kickdown cable really do? - Third Generation F-Body Message Boards
Sponsored by South Bay Fuel Injectors
Click Here
Thread Tools Search this Thread
Old 03-06-2003, 08:53 AM   #1
Larry Dunlap's Avatar
Car: '91 Formula
Transmission: TH350 built
I put a Lokar Throttel cable and bracket on my car becuase Im using an LT1 Throttle body. You must use a Lokar transmission kickdown cable as well so I got one of those too. I put on the bracket and the Throttle cable last night but didn't have time to put ont he kickdown cable. Someone told me that all it did was to downshift the tranny at WOT so I figured I didn't need that. Well apparently it does a lot more. I figured I take it for a test drive to feel the throttle cabel with the kickdown cable just laid to the side. It would not shift out of first at all, no matter what gear I put the selector in. Finally I stomped on it and is shifted once really hard. I figured I might screw something up so I went back home. I have the kickdown cable and I will put it on tonight, but what does the kickdown cable really do.? Also I will need to adjust it properly as the Lokar one is adjustable. What do I look for there?
Larry Dunlap is offline vBGarage Page   Reply With Quote
Old 03-06-2003, 09:13 AM   #2
The TV cable on these is more than just a kick down cable like on a TH350 or something similar. These cables as you have found out totally alter the shifting points when not adjusted properly. This topic has been addressed but hard to find. Here is a link to one,(most likely not the most helpfull one).
http://www.thirdgen.org/techbb2/show...ble+adjustment
Or do a search for cable adjustment and you will find more info!
Good luck!
85TPI400 is offline vBGarage Page   Reply With Quote
Old 03-06-2003, 11:21 AM   #3
Jza
Jza's Avatar
Calling it a "kickdown cable" is actually very midleading. It's actual name is a TV cable or Throttle Valve cable.
It slides a valve in and out of a bore to adjust the pressure which alters shift characteristics to better match the throttle position. For example, at low RPMs you don't need much pressure on the clutches to keep them from slipping, but if you were to increase RPMs and left the pressure the same you wouldn't go anywhere. It needs to increase the "grip" on the clutches in order to keep up smoothly with torque. Thus the valve.
Older transmissions like the TH350 used a modulator which measured vacuum in the manifold; an indirect indicator of throttle position. But when the pedal is floored it needed a seperate circuit to kick back down a gear which is what you need if you're flooring it. It's more or less an on/off deal. It's either kicking down, or not kicking down.
The TV valve is proportional, and very sensitive to it's position in the bore. If you have it adjusted incorrectly, you can ruin your transmission. You won't have enough pressure at higher RPMs and smoke some clutches, or you can have too much pressure and blow seals. Your short trip probably wasn't enough to hurt anything...much. You did say you stomped on it..uh oh..
Jza is offline vBGarage Page   Reply With Quote
Old 03-06-2003, 03:05 PM   #4
Car: '91 Formula
Well I didn't really stomp on it to the floor, just enough to get it to shift though, and it did shift very hard. I did that twice and went back. Hopefully no seals blown, Im goint to install the cable tonight. So just adjust it so it shifts smoothly as before I guess.
Thread Thread Starter Forum Replies Last Post
Looking for Canadian vendors to save on shipping, know any? TinnMann2 Canadian Region 11 04-18-2016 01:57 AM
quadrajet throttle bracket? armybyrd Carburetors 3 10-20-2015 04:57 AM
Cable-X Speedometer Signal Converter TMZIrocZ350 Engine/Drivetrain/Suspension Parts for Sale 1 10-07-2015 01:09 PM
Current Firebird Market Poll Report Midwest bjpotter History / Originality 17 10-04-2015 08:48 PM
A/C Re-hook up 84 z28 mcfastestZ28 Tech / General Engine 1 10-01-2015 12:23 PM
Go Back   Third Generation F-Body Message Boards >
Tags
back, blow, cabile, cable, do, kick, kickdown, parts, pressure, sensitive, shift, th350, throttle, tranny, trans, transmission, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All content copyright 1997 - 2014 ThirdGen.org. All rights reserved. No part of this website may be reproduced without the expressed, documented, and written consent of ThirdGen.org's Administrators.
