Rebuilding Lb9 To 300 Hp
1 Post
Car: 1986 IROCZ
Engine: LB9....rebuilding coming soon
Transmission: rebuilt 700R4
What are cheap and proven parts combo to acheive this Im trying to keep the engine rebuild under 1500
1 Post
Car: 88 IROC Convertible
Transmission: Raptor 700
try PMing Sitting Bull, i know he's got his 305 running around the 300 hp range. Also search for a huge article by Sitting Bull a while back which showed you how to port and polish your 305 heads to make them flow i think something like 90% of what vortec heads would flow which is damn good in my opinion. Anyways good luck to you
Car: 04 GTO
Transmission: M12 T56
Sitting bull is full of ****. He's never even been near a track let alone a dyno, his 300hp estimate is pie in the sky dreaming. Hell, along with his 300hp estimate he'll also proudly proclaim that the same simulators say he'd run mid 14s. So i guess my stock LB9 is making 350hp then.
If you want to make 300hp for under $1500, go straight to a 350 and don't look back. Any basic 350 with a mild cam can easily make 300hp. True 300hp 305s are not that common for a reason. At the least it'd have to be a well matched combo and be near perfectly tuned.
listen to ed on this
i'm sure if you ported you lb9 heads with a 1.94 valve job, and put a comp 212-218 cam, then do the chip you should atlleast be 280 hp , now i no for the stock exhaust systems on my 86 305 tpi ,it has the 3 inch stock, with the 3.42 gears,
i'm telling you here 1500 dollars won't be enough to run in the 14;s with peanut cammed 305 ,thats my opinion
Car: 1998 Z28 convertible
Transmission: 700-R4
1983 Berlinetta with 1985 305 TPI, stock cam & chip, headers, hi flow cat, 700-r4, 3.08 pegleg, 225/60/14 Goodyear GT+4's
14.997 @ 94 mph Mid 60's with high humidity at 600'
Car: 1988 IROC-Z
Engine: LB9
id dont think its possible to get 300hp from a LB9 for less than 1500...if im wrong, id love to see how its done...could cost twice that
no green
01-09-2016 09:22 PM
Royal_Z
09-30-2015 08:45 PM
