Electrical Problem
Old 12-17-2003, 04:12 PM
john_iroc's Avatar
Car: 89 Iroc-Z
Electrical Problem
I have a problem without having power locks, power mirrors, power truck, interior lights and horn. I am pretty sure it is a relay but don't know which one it is, so if anyones know can you reply back.
Old 12-17-2003, 05:02 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
I don't think any of those items use a relay.
Have you checked the fuses? All those things sound like they may be on the same fuse. I think it's called the "cust" fuse.
Welcome to the board!!
Old 12-21-2003, 09:45 AM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
that happened to me, my power windows worked and thats it. my cig. lihter didn't work ethier. it was my cig. lighter that shorted out and caused the fuse to blow. so check your fuses
Old 12-21-2003, 10:35 AM
3504mula's Avatar
Car: 90 Formula
If your fuses are fine, there is a relay that I believe powers those...On my car it is right behind/above the hood release and has "f e d c b a" on it-it is called the body wiring relay. But definitely check your fuse marked courtesy-if this is the problem, the cigarette lighter would not work either. The main cause that I have seen is a penny or foil gum wrapper falling in the lighter port....
Old 12-21-2003, 05:11 PM
subsonic9's Avatar
Car: 86 IROC
Transmission: WC T5
It happened to me also. My foot knocked the small silver box looking thing on the fuse block out of place. I put it back in and got the everything back.
Old 12-21-2003, 07:59 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Don't have a schematic for a 89 IROC but, looking at a 87 GTA/Firebird schematic I see a fuseable link that supplies power to the "tail lights" and "ctsy" fuses. You mentioned the "power truck" wasn't working. If you meant the "hatch pull down unit" that would make sense because the hatch pull down unit is powered off the same fuseable link as the tail light and ctsy fuses are.
In my schematic, the following are powered from the same fuseable link (some items may not apply):
Hatch pull down unit (no fuse shown for this).
Tail lights (thru the "tail Lts" fuse).
Power antenna, horn relay (forgot abt that relay), dome light, inst cluster (digital), release switch (??), courtesy lights, cig lighter, glove box light, factory radio (memory power), outside mirrors, door locks, and cargo compartment light all go thru the "Ctsy" fuse.
If all these items quit at the same time, including the hatch pull down unit, I'd be looking for that fuseable link. Unfortunately, the schematic does not show where the link is located. I'd start with the ones down by the starter though.
Old 12-21-2003, 09:53 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello John_iroc,
Check your "ACC" (accessory) fuse, it supplies power to the items you have mentioned. The fusible link that was mentioned in an earlier post, is located at the starter solenoid and supplies power to the fuse block. If it turns out that you need the schematic for it, I have the wiring schematics for a 1989 Iroc.
The Trickster!!!!!!!!
Old 03-30-2004, 06:28 PM
john_iroc's Avatar
Car: 89 Iroc-Z
Trickster, Can I get the wiring schematics from you?
Old 03-30-2004, 06:59 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It's in your e-mailbox
Old 03-30-2004, 08:04 PM
john_iroc's Avatar
Car: 89 Iroc-Z
Thanks for the schematics Trickster, really good help.
Old 12-02-2012, 05:15 PM
Phil219's Avatar
Re: Electrical Problem
I have this problem too...radio station lights,power locks,windows,trunk release, and interior lights don't work...they worked fine about an hour ago...fuses are fine...what else should check
toones
01-06-2016 06:00 PM
BlackphantomZ28
08-22-2015 01:00 PM
Dialed_In
08-20-2015 01:45 PM
Tony Ferrarri
08-11-2015 07:59 PM
Quick Reply: Electrical Problem
