Throttle Body Sticking
Old 02-17-2005, 09:30 AM
profiveo's Avatar
Car: 1992 Camaro Z28
Engine: 350 L98
Car is an 86 Iroc with TPI. We just got done replacing the intake manifold gasket so we had the tpi unit off. Well now the thing that moves when you press on the throttle is sticking a little bit. That causes the car to idle higher than normal, and sometimes it wont go back down. Why is it sticking and what can I do to fix it? Any help is appreciated. If you guys dont know what I am talking about I can take a picture of the part.
Old 02-17-2005, 11:45 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Check for a slightly bent throttle body shaft. My Holley sticking a little every now and then at low RPMs (just above idle), and it was the little lever on the back of the TPS dragging on the side of the throttle body. Coupl of small washers as spacers solved that problem. Could always add a throttle return spring, but that;s addressing the symptom instead of fixing anything (and would probably just be a temporary fix anyway).
Hope this helps a little bit. Good Luck!
Old 02-17-2005, 03:26 PM
xtremeirocz's Avatar
Car: 1986 Irocz- Houstons Fastest Street
Engine: 408 LS1 w/ 2 stage
Transmission: Turbo 350
Axle/Gears: 3:73,3850 lbs , best of 9.92 @ 138
i had the exact same prob on my 86, it was a small vacuum line binded between the fuel rail front crossover and the upper plenum. the line was ruptured and bleeding off vacuum making it idle high
Terrell351
06-13-2021 01:13 PM
Azrael91966669
25
06-20-2017 04:04 AM
mdtoren
08-16-2015 05:45 PM
ZZ42Fast
08-10-2015 08:20 PM
Quick Reply: Throttle Body Sticking
