I dont know the importance of fuel pressure BUT
Mine is reading at 32-35 psi when at idle and reving. I know it could be as low as 30 compared to normal 40 and should be fine.
HOWEVER. I have 3" hooker cat back system. Soon to put high flow cat. Also I have the edelbrock TES headers along with the slp runners and edelbrock tpi base intake.
So am i loosing hp due to fule pressure level? If so what can i expect to get hp and torque wise if i get an after market fuel pressure regulator and up it to about 48 PSI ?
I am certain I will get lots of feedback right?!?
Sam
Sam
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Fuel pressure is inversely proportional to vacuum.
As vacuum decreases fuel pressure increases, that's why it's highest when the engine is off, or at WOT.
If your losing pressure as you go to WOT, you either have a bad regulator, or fuel pump.
Once you solve this problem set the static fuel pressure at 43psi with no vacuum.
Reconnect the vacuum, and bump the pressure up 2psi at a time until there's no increase in power.
1 Post
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Because of the vacuum situation, you are supposed to check the fuel pressure with the engine warmed up and running at idle with the fuel pressure vacuum line pulled & plugged. On my previous stock car, I had 44 psi with this method. With the vacuum line hooked up, the fuel pressure was about 36 psi.
With full mods, I am now running 52 psi / 44 psi.
I think your fuel pressure is a bit too low. IMO.
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Only way to quantify any 'loss' of power is at the track or on the dyno. Have you observed the pressure readings as mentioned above?
Thanks,
well mine was tested with the vaccum line hooked up. and it read 32 then when reved it would jump to 35-36 then steady at 32 again but now at higher revs.
So if i unplug and plug the fuel pressure regulator vaccum i will increase the pressure? Or should i buy an adjustable pressure regulator?
Car: 1982 Z28
Originally posted by sam
Thanks,
Thanks,
If you want more pressure than that, it's time for an adjustable regulator.
And the only real way to know if you need more fuel delivery is with a wideband O2 sensor and some street or dyno time. Adding fuel to an engine that doesn't need it reduces power production...you could spend the $$ and end up slower.
R3500
08-17-2015 12:16 PM
92camaroJoe
08-13-2015 06:07 AM
