In Need of Quick Fuel Injector Info...!
Old 05-06-2006, 06:32 PM
neagan's Avatar
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
Hello! I am really new to this board and to the 3rd Gen Camaro's. I've been searching the old posts for a several hours but have run out of time.
Issue: Fuel injectors are leaking, car runs like a piece of trash.
What I Need: Replacement/Rebuilt Injectors.
Problems Solving Issue: {1988 350 IROC } My wife bought me this car and it needs new parts from one end to the other; it's truelly nickel and diming me half to death. For this issue, I just want a quick fix that is cheaper so I can concentrate on other areas.
It's my understanding that this engine takes #22 pound factory injectors;That there are 9 injectors for this year, that there are other options out there; Ford injectors will cost me approximately $300-$400 and are very consistent balanced items. Accel injectors are riddeled with problems; Factory injectors can be sent out to be blue-printed.
Are there any other options worth considering? Probably the cheapest solution would be to get a spare set and have them rebuilt and just switch them out???
What engine/vehicle years could I pull these out of and have them just easily swap??? I keep reading posts that mention LS1 injectors; what is the purpose'/benifit? are they a quick swap????
What else should I be looking at?
Thanks to anyone who responds. I need to start resolveing this problem this next week if at all possible. Oh, I am planning on keeping this engine fairly stock, but the intent is to wring out as much performance as is possible with basic performance tune-up and basic ignition/exhaust/chip/ect. items; no forced induction or fat rebuilding of heads or block.
Nitro
Old 05-06-2006, 06:46 PM
joejoe's Avatar
Car: red one
Engine: on the floor
Transmission: next to engine
Axle/Gears: the ones that turn
go to fiveOmotorsports.com got my 22's for about $215
Old 05-07-2006, 12:17 AM
neagan's Avatar
RE: replacement injectors....
Wow, that's a low price; were they new or rebuilt?? If Not, Would you even consider rebuilds???Nitro
Old 05-07-2006, 01:29 AM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
Well, if you just need a quick fix for now, the car will run on the 19lb. injectors, just not properly. I believe it will run a bit lean. Then you can focus on more important issues until you have money/time to come back to the injectors again in the future. Though $215 for all 8 injectors is a steal and I would do that...rebuilt or new. Beats messing around with improper or used questionable injectors/cheap quick temporary fixes.
bryan623
03-22-2021 06:43 PM
sweet_87_iroc
09-25-2015 10:01 PM
kyleb24
08-15-2015 08:24 AM
Firechicken86
08-12-2015 10:07 PM
Quick Reply: In Need of Quick Fuel Injector Info...!
