Vortec TPI manifold?
Old 07-21-2006, 07:18 AM
SS ninja's Avatar
Engine: 5.7 vortec crate w/TPI
Transmission: 2004r
Any suggestions for what manifold to use on a motor with vortec heads?
Is it difficult to modify the stock intake?
What options besides the edelbrock intake do I have? (If any?)
I'd really like to keep the heads that I already have on this motor (Currently carb'd)
Thanks,
Dave
Old 07-21-2006, 08:24 AM
CC89Formula's Avatar
Car: 89 Formula
Engine: 5.7 TPI
scroggins dickey sells a vortec TPI base, and someone also has a vortec holley stealth ram, but i cant seem to find those.
Old 07-21-2006, 08:34 AM
Vanguard's Avatar
I have used both the stock intake and the scoggin dickey intake with the vortec heads on my 87 formula 350.
The stock intake does fit by adding holes in the heads but the ports do not lineup that well.
I used a large felpro gasket and managed to seal everything up.
The swap to the vortec heads with the stock intake gave me noticably more power and after adding the scoggin dickey intake traction became an even larger problem.
I still have not added the exhaust EGR tube yet but it still runs excellent
Old 07-21-2006, 09:50 AM
SS ninja's Avatar
Transmission: 2004r
Awesome, thanks for the advice!
The only tough part is shelling out the $400 for the intake now, haha.
I'm still used to carb intakes which cost 1/2 that.
Old 07-21-2006, 09:58 AM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
Is this it?
Weiand Vortec EFI Stealth Ram Intake Manifolds: WND-7542 - summitracing.com
Old 07-21-2006, 10:47 AM
SS ninja's Avatar
Transmission: 2004r
yeah, I think that's it, but I'm more interested in this:
TPI Vortec Lower Intake Baseplate :: 12498060 - SDPC
Any improvement over a stock base, or does it flow the same and the only difference is that it bolts up to vortec heads?
Old 07-21-2006, 11:20 AM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
I've heard that virtually everything out-flows the stock base...
OK, being more serious, I would think that the intake would give you a noticeable improvement over stock.
Old 07-21-2006, 04:57 PM
Car: 89 Formula
Engine: 5.7 TPI
thank you
Old 03-29-2007, 08:24 AM
jaysfs's Avatar
Car: 91 z28, 07 trailblazer ss
Engine: lt1lt4 hot cam,ls2
Transmission: t56
Re: Vortec TPI manifold?
so did you get the intake for your vortec heads? notice a difference? I got the vortec heads too but waiting to buy the scroggins and dickey manifold
Old 03-29-2007, 11:11 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Edelbrock makes the Vortec TPI intake manifold for Scoggin Dickey, but Scoggin Dickey sells it for the least, at $399 last time I checked.
Fast355
12-02-2016 06:33 PM
Hawkeye1980
08-31-2015 07:09 AM
theurge
08-21-2015 12:46 PM
st.evel07
08-13-2015 06:15 PM
Sanjay
08-12-2015 03:41 PM
Quick Reply: Vortec TPI manifold?
