TPI OBDII - Thoughts/Opinions
#103
Car: 1983 G20 Chevy
Transmission: 4L60
Then again, I am working with a TBI setup that will never be as acurate as a MPFI setup due to the wet manifold. The fuel vaporizing in the manifold also directly effects intake charge density and makes for fueling changes due to weather, engine temp, etc.
#104
Car: 91' Z28 T-TOP
are the express van 350s 4 bolt or 2. I am in the market for a 350 to biuld and if they use 4 bolt mains than i can go to a junk yard and just pull everything at once.
#106
1 Post
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I was wondering. For knock sensors they list one for under 8500 lbs and 1 for over 8500 lbs. Both for Vin R though. My GF and I ended up using the under 8500 GVWR one. Think the other one would have a differant effect.
S10, we tuned Erins car just a little on the street and we got knock with hers so we know it works. Its weird mine never showed a count anywhere.
#108
Car: 1991 GTA
Engine: 5.7L L98
Transmission: 4L60
Can someone make this a sticky..... This sounds like the future for Thirdgen ECM tuning unfolding before us.
#109
Car: 1991 GTA
Engine: 5.7L L98
Transmission: 4L60
Can i got a question. Do you need to change to a 4L60E tranny for this new ECM style. What about the Throttle Body do you have to use a LT1 style TB instead of the L98 Style.
#110
Car: 1983 G20 Chevy
Transmission: 4L60
I am not sure, but I doubt it. I know the TBI PCM used from 1993-1996 and the LT1 PCM can be used without the 4L60E being attached.
#112
1 Post
Car: Formula
Engine: 6.0 LSX
On my formula I run the 700R4 BUT There is no lockup available. I am installing a 79 dollar kit from TCI to correct this. MPH and cruise work perfectly. Its independent from the pcm. B
#113
The PCM doesn't know what kind of throttlebody you are using. The PCM uses 3 wires for the TPS and 4 wires for the IAC ( idle air control ) motor, so it's the same as an LT1 or L98. The 411 has 2 speed outputs, use one of those for the cruise. You don't have to use a 4l60 or 80 trans, but the cool part of using one of them is that you can tune shift points, line pressure, and when the torque convertor locks up, and more.
#115
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
You have oxygen sensors for each bank, map and maf, tunable trans functions, and a host of other stuff.
#116
Thank you for the information. So I would have to also snag that portion from the donner car and fit it to mine.
Looks like I need to start hitting the local junkyards for Express Vans wiring harnesses. Are there any others wiring harnesses that will work? Like the Tahoe and Silverado's?
#117
Engine: LB9
Axle/Gears: 3.55
I think someone on one of the threads used an S10 harness.
There is a thread on about 4 different forums that I know of. It seems that this changeover is gaining momentum.
I got S10Wildside to build one for me.
I have since pulled one from a 2001 Savanna in case I ever need it. The junk yard guy gave it to me to take it out. Kinda hard to turn down.
By the way, there's more on the DIY board at
https://www.thirdgen.org/forums/diy-...ml#post2801225
69ghost and I started discussing this a year of so ago, and started looking for a way to make the changeover before we found out that other people had already done the change, or were working on the same thing.
The swapping of info from everyone is helping everbody.
Thanks, guys.
Thanks, guys.
#118
Car: 1983 G20 Chevy
Transmission: 4L60
Thanks, guys.
Thanks, guys.
#119
Engine: LB9
Axle/Gears: 3.55
That's great to know.
I am doing the 411 project in a 41 Chevy pickup and wasn't sure if a stock harness would work, so I got some measurements and S10Wildside helped me out.
I have my PCM and all relays under dash hidden.
#121
1 Post
Car: Formula
Engine: 6.0 LSX
I didnt connect anything to the 411 for the cruise. It worked itself from the bufferbox I assume. Also when S10 made my harness he built in a ALDL for me. Everything bolted right in and worked perfect on both cars
#122
1 Post
Car: Formula
Engine: 6.0 LSX
The 355 with blower should be running this weekend. We'll let you know how everything goes. I also just purchased a 4L60E for my Formula. its going to get a once over in January and should work perfect. I'm really diggin the electronics of it.
Also this seems so eay but its funny how I look back in the days of chip burning and alll the other crap that goes on in the DIY board lol.
#123
EFILive has an auto tune feature for volumetric efficiency that requires their custom OS (operating system) that's speed density mode only. You can enable the MAF later, but I've been told that enabling the MAF after the speed density auto tune requires changes to the MAF table. It's my understanding that the MAF is a redundant source of information for air/fuel values and is really not necessary.
#125
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I was all set to convert my car to SD, but I guess I will have to do this mod instead.
does fuel economy go up at all?
#126
1 Post
Car: Formula
Engine: 6.0 LSX
Well Before my swap my best with SD was 16mpg with the 411 now we achieved 19 with NO converter lockup yet and a AF ratio of hi13's low 14's its not even tuned for highway yet. I expect mid 20 numbers from the 383 and high 20's even 30 for the 355 since the 355 was pulling 22mpg before the 411 swap.
#127
Car: 1983 G20 Chevy
Transmission: 4L60
#128
1 Post
Car: Formula
Engine: 6.0 LSX
Pics!!! First pic is the 411 ECM and Mikes Custom Harness. Second pic is the Accel Billetech Distributor and Taylor Spiral Pro wires.
Third pic is the Crank Sensor and the last one is where I put the stock bracket from an S10 pickup. I also added an MSD coil to replace the GM one.
#133
Engine: LB9
Axle/Gears: 3.55
He built a complete 411 harness for me last summer, but I know he has a lot of other stuff going.
A really good job, by the way.
#134
1 Post
Car: Formula
Engine: 6.0 LSX
Mike made both my harnesses. Since the Formula one was the first thirdgen one ever made its missing the Crank relearn wire and a few wires had to be lenghtened, but when I got the second harness for the RS (Girlfriends car) it was all good to go with everything. You do have to mesh your current harness in with the custom one as well. With doing it correctly and making it look factory it took me about 3 hours making sure the connections were good, wire loom was on and it was taped good. I imagained I could have done it in 1.5 but I took my time and watched TV at the same time in the basement lol. I also highly recommend him as a harness builder. I am also going to be swaping everything over for "Justin89Formy's" car as well in about 2-3 months. HIs I believe will be the first thirdgen with the OBD II and a T56 combo. The RS is running with the 700R4 and thats good too. We shall see about the 4L60E in my car in about 3 weeks when the tranny comes back from the builder.
BTW All 3 cars will be SD only. No MAF
#136
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
This does sound like an intriguing conversion......
#137
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Not seeing myself do it this year but, you know how that goes. Always wanted the E trans, this conversion makes that possible.
Couple Q's,
Did I see that this PCM code handles boost?
Anybody do any code work on this for adding a WB?
(or just hacking code in general)
#138
1 Post
Car: Formula
Engine: 6.0 LSX
No prob. I will let you know when we do it and you can help with everything if you would like. You can even come to the machine shop if you like to see how to get the balancer reworked. (Victory Engines 130th / Lorain ) Yes, this ECM handles boost. We are running a 2 bar on my GF's car. As for tuning and code work, I am unsure. hit up Jamy at info@LSRacingChips.com
#140
1 Post
Car: Formula
Engine: 6.0 LSX
If you look hard at my pic of my ecm, he builds you an fully funtional aldl that can mount in the same spot
http://www.cardomain.com/ride/827967 Supercharged Car Pics with 411
#142
1 Post
Car: Formula
Engine: 6.0 LSX
You gotta love going to autozone.... After we did the swap with blower into Erins RS it was throwing a code and before blower it wasnt. I was like hmmmmmm. So I go to autozone and was like my ses light is on and I need a code pulled, but its an OBD II and they were like HEH???? LOL Gotta love the look on their face. I ended up with a Code P1045 (P1035 maybe) which was Manufactor controlled ignition error. (Turns out my dis was loose and moved passed the -2 +2 degrees zone meaning the crank and cam sensor were not in sync anymore)
#144
Victory did my heads for me last year, know right where he's at.
Shoot me a PM when its time.
I'd like to see a program out of one of those, can anybody point me to a bin?
#145
1 Post
Car: Formula
Engine: 6.0 LSX
I love working with those guys at Victory. Ray built my shortblock and Erins also. Accually theres no bin anymore. Its called a PCM Flash. You need EFILive , HP Tuners or Tuners OBDII to read it.
#146
Engine: LB9
Axle/Gears: 3.55
I have uploaded the cal files at http://www.monodax.com/forums/tunercat-files/ for the L31/4L80E and L31/4L60E Express Van under two different files. Anyone is welcome to do what they wish with them. There is a vin # in the file also.
You will need TCII and def file for 2001-2003 GM truck to work with them though. This is the same PCM that works the trucks, vettes and F body cars also, but a different flash. I bought one S10 PCM and re-flashed it to the Express flash. I don't have anything else to read OBDII stuff with.
I'm seriously thinking about buying EFILive this spring when I can get back on my 41 truck/OBDII/Ramjet project.
The more that work on this stuff, the more we all know.
Thanks,
Ron
Thanks,
Ron
#147
#148
I'll be building a third gen length 411 harness this weekend. If I have enough time, I'll take pics and get them online.
I wish I could say the stock TPI harness could be easily converted to the 411, but it would be a pretty big job...absolutely nothing like converting from the 165 ECM to the 730 ECM. If someone were to ask me to convert their TPI harness to the 411, the labor would be worth much more in the conversion than building a new harness.EFI Connection has all the items you'd need to do the conversion, but keep in mind it would be a really big job.
#149
