Post Your TPI Quarter Times! Or Eighths!
#151
Car: 1991 Z28
Engine: 350 tpi
Axle/Gears: LSD
Re: Post Your TPI Quarter Times! Or Eighths!
Only just seen this, Ok !991 Z28 350 tpi 700r4. 120000 on the clock only thing done to the car is 4th gen interior and a rebuilt lsd everything is else is as GM intended. !st ever trip to the track and the best time of the day was 14.01@ 98 mph. This was at Santa pod raceway in the UK on a cloudy day.
#152
Car: 1991 Z28
Engine: 350 tpi
Axle/Gears: LSD
Ok I thought I posted this but never mind will try again. 1991 350 Z28, the only thing done to the car was a fresh built lsd and a service thats it. The car was as GM intended from the factory. 14.01@ 98mph and thats a standing quarter on street tyres with jack and spare in the trunk. That was also my first time at the track.
#153
Car: 1991 Camaro B4C
Engine: L98 350 cid (5.7L) TPI v8
Transmission: 700 R4 auto trans
Axle/Gears: 10 bolt w/girdle & 3.42 MotiveGears
There are a lot of simular post about this.
I posted this back in 2007.
145,000+ miles on the odometer
fastest 1/4 mile time:
13.525 @ 99.95 mph
@ KCIR 11/12/2006
Same night:
fastest 1/4 mile speed:
13.611@ 100.87
@ KCIR
Many 1/8 mile passes in the 8.88 sec range.
Race weight = 3660 lbs. with me in it.
I've been cash poor for a while now.
so no futher mods have been added.
Added:
Jet TPI air foil...
K & N air filters...
Gutted air boxes...
TPIS plug wires...
Bosch platinum plugs...
Throttle body coolant bypass...
Empire Inland aluminum drive shaft...
March steel underdrive pulleys # 4405...
Edelbrock ceramic coated TES headers...
Flowmaster American Thunder 3\" Catback...
Catco dual cat replacements...
TPIS MAT relocation kit...
Meziere electric water pump...
Motive Gear master kit & 3.42 gears...
Spohn adj. torque arm...
UMI lower control arms & relocation brackets...
UMI adj. pan hard bar
13.525 @ 99.95 mph
@ KCIR 11/12/2006
Same night:
13.611@ 100.87
@ KCIR
Added:
Jet TPI air foil...
Gutted air boxes...
TPIS plug wires...
#154
Car: 87 GTA
Engine: 350 tpi
stock 305 tpi 15.2 at 88mph will get new times soon the moter has a top in build accel lower,22lb inj,arizona speed shop runners,custom trans,stock gears hopeing for high 13s
#155
anyone run with mods same as mine?
MAF L98 fully built
SLP Air Foil on Stock Throttle Body
Ported Plenum
Ported SLP Runners
TPIS Big Mouth Base
Stock Heads
Dyno Dons 1 3/4 Headers
3" Y Pipe
3" Cat
3" Flowmaster Cat Back
3.73 Posi
Firestone Firehawk 245 50R16 Tires
Built Tranny 2100 Stall
Convertible
I know the verts are heavier but im hoping for mid 13's - maybe too much to hope for on the stock heads
MAF L98 fully built
Ported Plenum
Ported SLP Runners
TPIS Big Mouth Base
Stock Heads
3" Y Pipe
3" Cat
3.73 Posi
Convertible
#156
Location: *member since 1999, I think - just can't remember my old name, and the big site crash...*
Engine: 5.7L L98 TPI
Transmission: 700r4 Automatic
1/4 mile times:
1989 GTA 5.7L T-top car, 3.27 rr, single catalyst
When stock, she ran 14.3 @ 96
A few mods - cold air inlet, flowmaster muffler, underdrive pulley, and performance resource chip, she ran 13.9@101
With AFR Cylinder heads, Superram, 58mm tb, she ran 13.1@109
Changing to the 6.3L from the 5.7L, she went down to 12.2@115 mph
#157
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
I don't think I updated from my trip to the track last Sept. 4010lb 89 Jag convertible, 89 Camaro based motor, stock cam, 1.6 rr rocker, ported plenum, edelbrock runners, tpis intake, 52mm tb, 22lb injectors, shorty headers, emissions legal exhaust, 700r, 2800 stall lockup converter, 3.23 gear with dot radials, non drag radials. With a mild, over the internet tune that easily passes emissions, the car ran a new best of 13.39 @ 102. This far exceeds my expectations for this combination. My fear is they always run the best, just before they blow up!! lol!
#158
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
87 IROC L98 auto w/ B&M shift kit, SLP converter, 3.27 9 bolt, Flowmaster 2 on the left exhuast.. "free mods" It ran a best of 14.2 @ 93ish dynoed 195 hp 280 tq
86 Firebird L98 T5 swap SD conversion, 3.42 rear.. Flowmaster dual cat exhaust.
14.3 @ 94ish never got it on a dyno, but it was the engine that was in the 87 originally.
88 IROC L98 SD conversion, T56, Dana44 w 4.10 gears, SLP 1 3/4" headers, Magnaflow exhaust 14.3 @ 93 dynoed 220 hp 370 tq
#159
Car: 1988 Pontiac gta
Engine: 5.7 tpi
Axle/Gears: Borg Warner 3.27
Stock 5.7 tpi 1\8 mile
60 Ft 2.04
9.46 et
73 mph
I drove 30 miles down the interstate at 75mph
Pulled right up and ran 3 times down the track (slow Sunday)
Turned around and drove 30miles back home
No mods
60 Ft 2.04
9.46 et
73 mph
No mods
#160
Car: 89 Firebird Formula
Engine: 383 tpi vortec heads Xr 269 cam
89 formula
305 tpi
6.8 psi boost
Dyno don headers no. Cat
3" catbck
3.73 gears
Meth injection
KN intake
Ac
Air pump
60. Ft 2.22 s
1/8 9.333 s
1/4 14.5s
95.3 mph
Only able to do two runs and first was disaster
Should I be expecting more? I thought I would do better
305 tpi
6.8 psi boost
3" catbck
3.73 gears
Meth injection
KN intake
Ac
Air pump
60. Ft 2.22 s
1/8 9.333 s
1/4 14.5s
95.3 mph
#161
89 formula
305 tpi
6.8 psi boost
3" catbck
3.73 gears
Meth injection
KN intake
Ac
Air pump
60. Ft 2.22 s
1/8 9.333 s
1/4 14.5s
95.3 mph
305 tpi
6.8 psi boost
3" catbck
3.73 gears
Meth injection
KN intake
Ac
Air pump
60. Ft 2.22 s
1/8 9.333 s
1/4 14.5s
95.3 mph
#162
Car: 89 Firebird
Engine: 355 TBI
I had a 91 Z28 LB9,Auto. It had no cat,smog delete,3 in exhaust, an aftermarket chip so pretty much bone stock. I was very surprised when it turned a 14.76 one cool fall evening. It would typically turn 14.85-15.10 depending on the weather, our summers are horrendous down here.
#163
60' 1.57
330' 4.79
1/8 7.50
MPH 90.81
1000' 9.84
1/4 11.83
MPH 112.98
91 Vette, 383, TPIS 113 heads, LPE 219 cam, AS&M runners, accel base, ported plenum
330' 4.79
1/8 7.50
MPH 90.81
1000' 9.84
1/4 11.83
MPH 112.98
#165
Car: 86 Trans Am
Engine: 305 LB9
305 tpi 120k
Bone stock 86 tranny
Magnaflow exhaust
1/4 on 87 oct = 16.92 was my first run
After warming up I got 16.83
Magnaflow exhaust
#166
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
89 formula
305 tpi
6.8 psi boost
3" catbck
3.73 gears
Meth injection
KN intake
Ac
Air pump
60. Ft 2.22 s
1/8 9.333 s
1/4 14.5s
95.3 mph
305 tpi
6.8 psi boost
3" catbck
3.73 gears
Meth injection
KN intake
Ac
Air pump
60. Ft 2.22 s
1/8 9.333 s
1/4 14.5s
95.3 mph
Unless those blowers are just THAT bad, but I don't see how that's even possible.
1992 Trans Am
05-10-2023 07:19 PM
Sanjay
08-12-2015 03:41 PM
