Vortec head spark plugs?
Old 03-27-2007, 10:56 PM
bonz's Avatar
Car: 89 GTA
This my be a dumb question but would the spark plugs for vortec heads be different than what are used on stock L98 heads. I didnt think about maybe needing different plugs until today.
THANKS
Mods. GMPP Vortec heads, Comp Cams XR269HR, Crane Gold Rockers, Hooker headers, SDPC intake manifold, free flow exhaust, Air Foil, De-screened MAF, TB Bypass, K&N filter, MSD Coil. To be installed, Edelbrock runners, BBK AFPR, SFC.
Old 03-27-2007, 11:41 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Vortec head spark plugs?
Yes they are different; the Vortec heads use longer plugs. You should get plugs for a 1996-1998 350 Chevy truck, as they came with the Vortec heads.
Old 03-28-2007, 11:46 PM
bonz's Avatar
Car: 89 GTA
THANKS for the help. Could it cause damage or performance loss by using the other plugs. Either way tomrrow I will get the right ones but was just wondering. THANKS again.
Old 03-29-2007, 12:12 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Mr43 off the top of my head, think thats right.
All the truck plugs are platinum and last I checked (multiple yrs ago) they didnt have a non plat equivelant in delco(sure thats changed)
I know they are extended reach plugs(long snout) and the MR was marine plug all the vortec crate engines use.
later
Jeremy
Old 03-29-2007, 05:15 AM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
Axle/Gears: 9 BOLT/ 3.27 GEARS
I was kinda wondering the same thing. Because my L98 plugs thread nowhere near towards the combustion chamber on my Vortec heads. I've heard that a specific Ac Delco plug will actually work. I don't remember the part number though. Maybe someone could enlighten the community.....
Old 03-29-2007, 06:01 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
NGK TR5
Old 03-29-2007, 06:12 PM
3.8TransAM's Avatar
If u actually search I've posted the exact plug a couple times.
I'm not at home with the car(at school), so do some searching under my name and you should find the delco number.
later
Jeremy
Old 03-29-2007, 11:03 PM
bonz's Avatar
Car: 89 GTA
I got the plugs today and will get them in and hopefully have it going by this weekend. I was told they are gapped at .60 and thats what is recommended. I have a MSD coil so that should help out with that big of a gap but just that that was a lot. Is that right. I didnt plan on spending $7 a plug but hopefully it helps out.
THANKS AGAIN
1992 Trans Am
05-10-2023 07:19 PM
84z96L31vortec
08-20-2017 12:16 AM
evilstuie
02-28-2016 03:33 PM
eightsixseven
08-14-2015 03:09 PM
Quick Reply: Vortec head spark plugs?
