LT1 injectors in a 350 TPI, will they fit
Car: 1985 Z28
Engine: LG4 305 with a few modds
will the LT1 injectors fit a 350 TPI... and will the computer be fine with them.... i found a set of LT1 injectors for 80 bucks but i don`t know if they`ll work, i don`t want to go reprograming my computer... i found out my computer already has a jet chip in it and i don`t want to go replacing it with another chip
Car: 1991 TRANS AM GTA
Engine: 5.7L TPI
Axle/Gears: 3.23 Posi
Re: LT1 injectors in a 350 TPI, will they fit
Yes, they should fit you may need a tune afterwards, though. That sure is alot of inj for a 305 though.
Car: 89 ws6
Engine: 355 afr195, hsr,gmpp cam, hs rr,
Transmission: t-5
Axle/Gears: 3.08
I believe he said it is going in a 350. The stock LT1 injectors share the same connector and will plug right in. They are 24lb. injectors. As far as will they work for your computer that may differ if you have spped density or mass airflow. I rememeber reading somewhere that stock pcms were able to read up to a 10% increase with no real problem and 24lb injectors would fit that criterium. Although with a prom tune you could optimize your performance better.
Engine: 5.7L TPI
Yeah he did. Geez, guess I need glasses. I am goin blind.
Car: 89 ws6
Transmission: t-5
Axle/Gears: 3.08
Car: 1985 Z28
LOL at shocker.... we all make mistakes... but my car is a L98 350 TPI in a 90 GTA so it`s speed density. thanks for the replys.
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
I had mine custome tunned. You will need an adjustable fuel pressure regulator though.
Car: 1985 Z28
Well i put a set of LT1 injectors in my TPI and it hasn`t run better since i`ve owned it... the factory injectors were bad and was running really rich put the LT1`s in and it fine.... gotta drive her around since i`ve only takin it around the block but i don`t thik i`m gonna need to touch it... i hope.
Car: 2005 Pontiac GTO
Engine: 364ci LS2
Transmission: 6 speed
Axle/Gears: 3.46
im going to be putting LT1 injectors in my car soon... im currently working with the 40# injectors the moron that had the car before me put on
Car: 1990 Iroc-z
Engine: LS3/LSA blower
so what was the final decision, did it need to be tuned or not?
Sanjay
08-12-2015 03:41 PM
