High-flow TPI Camaro air lid
#103
Re: High-flow TPI Camaro air lid
Now are these lids already for people that ordered or can I claim one?
#104
1 Post
Car: 1990
Axle/Gears: stock
let me figure this out. now math is not a strong point but you did this originally back in 07 - and its mid 09 now and you are still not done.
so if i put my order in now i can have it in the spring of 2011?
put me in
- really tell us when you are ready to sell them.
put me in
#105
1 Post
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
1bad91Z: Looks like you are still going strong here, thats good. I did not take the time to read all the posts since I posted way back when on here. Your airlid must fit under the stock hood, correct?
#106
Car: Faster
Engine: Than
Transmission: You!
Yes, the modified lid does fit under the stock hood, with the stock fastening snaps into the stock lower air filter housing.
To reply to tony_cogliandro's remark - I made two last year for close friends of mine. I waited until I not only collected more cores, but also had to find the time to make some more. I work two jobs and I'm in college (for a career change, but that's besides the point). The point is, I haven't had the extra time to make more until now. I apologize for the delay.
I have 1 out of the 4 cores completed (modified and painted). 1 that is half finished and 2 untouched cores. The one that is half finished will be completed this Saturday which will make the total completed lids to 2. The other 2 remaining lids will be completed hopefully by the following weekend.
One out of the four is already pre-sold. The other three are not spoken for as of today.
#109
Car: Faster
Engine: Than
Transmission: You!
That was pretty quick! 2 out of the 4 are spoken for.....
I'll take some pictures tomorrow if I can. I can't fit my hand in a stock lid, but I can stick half of my arm in the modified one!
#110
Car: Faster
Engine: Than
Transmission: You!
Update: 2 and 1/2 lids finished. Lid 2 is completed but drying overnight.
Here are some pics....
You can compare the modified one to a stock lid....
#114
Car: Faster
Engine: Than
Transmission: You!
You would just have to step it down with a rubber/silicone reducer (4 inch down to 3 inch or what ever size MAF that you have).
#118
Car: Faster
Engine: Than
Transmission: You!
Sale pending on 4th lid.....
To all receiving high-flow lids :
The first thing I recommend (if you haven't done so already), is to cut the bottom out of the lower air-filter housing (see picture, it's circled in yellow)....
You don't want to have an air restriction before the air even enters the high-flow lid!
Next, you'll need two pieces from www.intakehoses.com
The part numbers are:
C40B-400X10 (Silicone Sleeve 4" ID X 10" long - gloss black)
AL4X4 (Aluminum Intake Tubing 4" OD X 4" Long)
Before you order the above parts, please read below notes first!!
Notes:
You may want to measure how long of a silicone sleeve that you'll need "after" you snap on the new lid. Measure at least an inch onto the lid's outlet pipe to the base of your throttle body. 10 inch sleeve may work, but if you have a stealth-ram or mini-ram, you might need 11 inches or more. 10 inch sleeve worked fine for my setup though.
Next, you will have to insert the 4 inch thin-wall aluminum tube into the center section of the 10 inch silicone sleeve. This will keep the sleeve from sucking flat in the middle under acceleration.
Your factory throttle body hose clamp will work fine for connecting the silicone sleeve to the TB, however you will need one more of those same hose clamps for connecting the silicone sleeve to the high-flow lid's 4 inch outlet pipe.
Thanks again to those that purchased lids! I've put many hours into them!!
Please feel free to post your results once you have them installed and connected.
If you have any questions, feel free to PM me and I'll help anyway I can.
Thanks again and enjoy!
Michael (1bad91Z)
Notes:
Michael (1bad91Z)
#119
Car: Faster
Engine: Than
Transmission: You!
4th lid completed!!
I'm glad they are done!!!
Lid 1 - picked up locally yesterday.
Lid 2 - Will ship tomorrow morning cause they were closed today!
Lid 3 - Will ship tomorrow morning cause they were closed today!
Lid 4 - Completed today, sale pending (waiting on funds to arrive).
I have some pics that I'll size down and post later tonight.
#120
Car: Faster
Engine: Than
Transmission: You!
Lids 2,3,4 ....
Customer took the other lid before I could get a pic with all 4 together! Many, many hours displayed in this pic.........
I hand fit each lid to my car which has the factory hood and all lids snapped on fine and cleared the factory hood.
#121
1 Post
Car: 1989 Camaro
Engine: 383
Nice work
#122
Car: Faster
Engine: Than
Transmission: You!
Thanks for the compliment!
Did you feel a gain from the lid that you made? If so, then it was still worth it!
#123
1 Post
Car: 1989 Camaro
Engine: 383
I think it helped, but then my engine was new and my tune was off so I didn't really get to see what it would do with a stock lid.. I actually have another lid that I plan to modify but I haven't had time. I hope it turns out better looking than the first did.
Here is a link to the pictures of my lid and MAF sensor
https://www.thirdgen.org/forums/alte...af-sensor.html
#124
Car: Faster
Engine: Than
Transmission: You!
Yea, it's not a supercharger!!! But is does help. I felt a difference when I built one for my car.
Update:
4th lid is sold and will ship in the morning!
I may make one more before the end of summer if time permits, but I'm not sure. If I do, I'll post a pic of it here on this thread....
Cheers!
Update:
Cheers!
#125
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Just got my lid in the mail today, looks great. I am going to the track June 6th. I will test the difference between the stock lid and the modified one. The only drawback is that I will still have my MAF in. I am going to try and make either a 3.5 or 4 inch maf sometime this summer. I will also post the results of that later.
Thanks again mike
Thanks again mike
#126
Car: Faster
Engine: Than
Transmission: You!
Your welcome!
Just remember, if you do the bigger MAF, you are going to have a nightmare on your hands re-programming all the MAF scalar tables in PROM in order to get it to run right....
Even just using the bigger lid, you may want to bump up min. grams per second threshold at idle table from 45 gps to 55 gps in the PROM, if you haven't done so already.
#127
Car: 1988 Camaro
Engine: 383 Stroker
looks like this weekend is going to get rained out, now I hope I have time to either make a 3.5 inch or 4 inch intake to go along with my new airbox. We shall see how she works then!!
#128
Ok I have no fab work experience but I just picked up an air lid from a pick a part and would like to learn how to make one of these. It seems intimidating. My first question is how do you pull the lid apart without snapping anything?
#129
Car: Faster
Engine: Than
Transmission: You!
Not to be negative or anything..., but they are not easy to fab. I've been fabricating car parts for almost 15 years and it's still challenging for me to get them perfect.
To answer your question though, you have to cut the lower section off at the side seams and a couple of inches from the square air filter port, and then also at the neck. The pictures on the 1st page of this post will show you what the pieces should look like.
Hope that helps!
Hope that helps!
#130
Haven't seen this thread in a while.
Quick question for you 91Z. Did you ever get the chance to get one of your air boxes on a flow bench? Maybe one of the guys who purchased one has?
#131
Car: Faster
Engine: Than
Transmission: You!
I don't have access to a flow bench or the extra funds to have it tested...
Joeblue picked up some MPH and a few tenths with it I believe and that was necked down through a MAF!
#132
MAF may be a restriction but the box is definately a restriction. Bigger opening plus some type of ram air to those filters will help. You can go pretty fast with stock MAF with screens removed...how much to be gained by 3.5 or 4" MAF is still unknown. I didnt gain much with mine, actually ran about same... but I never re-dyno tuned it either... could have had some hp there
Bad91Z i have my stock airbox lid here, do you want it as a core for more mods?
#136
[QUOTE=1bad91Z;4312498]I don't have access to a flow bench or the extra funds to have it tested...
QUOTE]
Funds are everything aren't they?!
I always liked your air box mod. So much so that I had intended to purchase one of yours(or attempt my own) however I'm big on collected data.
Your engine combination is very similar to mine with the exception of EFI. I've always known the stock air box to be restrictive but with the photos you've provided I can see that is probably no longer the case. What I do question is the cfm capacity of the twin filters.
I can't seem to find any data (through K&N specifically) that shows that the filters will support the kind of horsepower I make. In one of David Vizards books, he states that one square inch of K&N filter material will support about 4 to 4.5 hp. TPI filters are 6x6 times 2. Thats 72 sq ins. About 288 to 324 hp. That could be a problem.
I love to see someones experience with big hp numbers and performance data using the OEM filter arrangement.
QUOTE]
#138
Car: 92 Z28
Engine: LS3
Transmission: TR6060
Axle/Gears: Strange S60 3.73
I'm trying to modify my stock TPI air lid to flow better too. I took some measurements tonight with play dough placed on lid and closed the hood I figure too that whole lid can be raised 1/2" and have enough clearance.
Running some calcs, location just after each filter are restrictions after raising lid 1/2". Area near bend over radiator is no longer restriction. From calcs, raising lid 1/2" will permit 1.64 times greater cross sectional area throughout lid.
Found below post where lids where flow tested. Lid without baffles and K&N flows around 550 cfm. 550x1.64 yields 902 cfm for raised lid. I'm trying to find out if two stock sized K&N air filters will be a restriction. I cannot find any flow data however if Vizzard is right, they will permit 240 HP (5.5"x5.5"x2x4). 400 HP needs a 10"x10" filter, almost twice size of two stocks combined.
I'm confused since wicked-irocz flowed 550 cfm with K&N's on lid. Using general rule of 1HP per 1.3 cfm, stock will allow 429 HP at 558 cfm and modified 693 HP at 902 cfm. I'm curious how Vizzard tested filters. Maybe filters flow more at high rpm's? Regardless maximizing flow to throttle body is our objective.
https://www.thirdgen.org/forums/tpi/...including.html
Here are cross sectional area calcs from measurements:
Area after filters (added two channels together)
10.31 sqin stock
15.81 sqin raised 1/2"
Bend over radiator
9.62 sqin stock
20.62 sqin raised 1'2"
15.81/9.62 = 1.64
10.31 sqin stock
Bend over radiator
9.62 sqin stock
15.81/9.62 = 1.64
#139
At one time I did the Camaro air filter calculations like you did using K&N's flow numbers per square inch. My numbers came out similar to yours. If our math is correct the two Camaro air filters are a restriction. I know on our dyno tests the Camaro guys remove the air filters.
#140
Car: 1988 Camaro
Engine: 383 Stroker
i just got my car tuned after the high flow air lid. before I had 469 horse and after 474 horse. torque before 455 after 488.4
no other mods done
no other mods done
#141
Car: 92 Z28
Engine: LS3
joeblue, modified box must still help a lot if you are making 33 more ft-lbs on a 383.
I thought about it some more. Another restriction is area just after radiator where lid converts to round pipe. Stock I figure about 7 sqin and up to 9.6 sqin in raising lid 1/2". You will have to heavily modify this area to open it up so cross sectional area matches 15.8 sqin area just after filters for raised lid. I think you just have to make lid wider at area past radiator to make it work.
Also, could you modify front part of lid so that two cone style filters can be placed down in "fog light" tunnels and ditch stock filters? I haven't removed my lid base to see how much room is down there. Two cone filters with 3.25 in pipe diameter each would yield 16.6 sqin. Cone filter that is 3.25x5.12x5.25 gives you 169 sq in of total filter area. http://www.aemintakes.com/search/pro...Prod=21-2110DK
Doing extra lid modification past radiator and cone filters results in flow of 902 cfm, cross sectional area of 15.8 sqin and 169 sqin filter area. This results in 676 or 693 maximum allowable HP depending if you use air flow or filter area. I know actual flow involves more than just cross sectional area. Interesting to note that FIRST intake 71mm (2.79" -> 6.1 sqin) diameter throttle body is 835 cfm. Also from wicked-irocz lid flow tests, removing lower baffles frees up about 50 cfm which is a 10% increase.
I wonder if these extra modifications above are worth it since joeblue is getting great power #'s with only raising lid 1/2".
#144
Car: Faster
Engine: Than
Transmission: You!
I built Joe's lid and several others. I did open the area over the radiator and the outlet went from the stock 2 5/8" D-port to a 3.5" I.D. round port outlet. I also recommend not only removing the baffles from the lower filter housing but also to gut it like the pic I previously posted with the yellow circle drawn around the area in reference.
Nice gains Joe, I take it you are happy with your purchase?
#146
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
Just to let you guys in this thread know if your interested I have a complete stock intake system with K&N filters out of a 1992 Z28 if anyone is interested,I now own a Trans Am and its not compatable,Just wanted to throw it out there if someone needed one to attempt to mod......These mods are really nice...just PM me for info I don't wanna be a thread jacker....
#147
Car: 92 Z28
Engine: LS3
I took of my stock lid base to install a junkyard unit where I cut off baffles. Looking down in front bumper area I am amazed how any air gets to filters in first place Engine air flow must have been an afterthought for GM. Maybe it's all in my head but engine feels more responsive even with baffles just cut off. Can't wait to try out modified lid!
Will cutting out fog light tunnels adversely effect radiator flow? I'm thinking about opening up top of tunnels for better flow to air filters and still have flow to radiator. I don't know if full cold air intake would remove too much radiator air flow. Thanks.
#148
glad im not the only one.. did mine back in 1993.. on my 92 Z28
made 6 or 7 of them for Guys back then.. cut all from sheet alumn. and pop riveted together.. also Cut the bottom of the Y's off and used sheet alumn on that has well to up the flow..
my car has been sitting for 7 years in this photo.. fogive the Dust
air flow seems to be the same for cooling..never had a prob..
my eng is a lingenfelter 383. 11.1 mech roller..ran just fine 190 on hot days..
#149
Ok Im in the process of cutting the lid open and it is a pain in the but to do. I'm using a dremel with a cutting disc and the plastic keeps on caking up on the disc. I got a abs pipe for the neck. It is the same size as yours, and wow putting it next to the origional in person their is a huge difference. Something I dont have are the abs plastic strips. Where do you get those, and what epoxy did you use to glue everything together?
#150
Car: 92 Z28
Engine: LS3
I had same problem with dremmel cutting disk. I bought another cutting wheel. It is all metal and basically looks like a small buzz saw attachment. I found that a hacksaw worked best to get started. Then I used a stiff putty knife and hammer to separate pieces. Take your time and keep adjusting putty knife position/angle.
