TPI/LT1 NOS plate system worries
Old 01-18-2008, 02:52 PM
psy4s's Avatar
I am running a 383 Chevy with a modified LT1 intake ported to twin 58mm
using a BBK power plus twin 58mm Throttle Body and 36# injectors. I have a plate style fuel injection setup that mounts between the Throttle body and Manifold. A wet system that shoots fuel and NOS into the intake.
............................1. 3...... 5..7
........................__l .ll. l___l. ll. l__
.................> H-l============= l REAR
.FRONT.... > H-l============= l
............................l. ll. l..... l. ll. l
.............................2..4...... 6..8
Standard Chevy Intake Pattern,
The 36# injectors are as usual at the cylinders just above each valve,
but the fuel from the injector bar has to move from the front all of the way to the back suspended in air. If there is even one low pressure spot between the front and rear, the suspended fuel will fall out of the moving air, since it is heavier than the NOS, and BOOM engine melt down.
I am of the opinion this could be a problem, or am I just over thinking this system?
Old 01-19-2008, 12:48 AM
customblackbird's Avatar
Car: 87 TA clone
Engine: supercharged 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Re: TPI/LT1 NOS plate system worries
im not sure i understand what ur saying about the fuel bar etc. if its the stock setup which it looks like it is and ur running the aftermarket TB with the nos plate inbetween, i dont see why its a prob. dont they supply u with everything to hook it Up? pics would def help
Hotrodboba400
12-10-2019 07:07 PM
92projectcamaro
01-18-2016 08:00 AM
Slush92RS
09-02-2015 08:56 PM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: TPI/LT1 NOS plate system worries
