Possible bad hei module?
Old 03-16-2008, 10:36 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
I have been having a problem of my car just stalling out on me. It would kick back up and go for a while, maybe even 3-4 days. Well one day it happened again so i thought it could possible be fuel. No fuel issues were present. I then thought maf. Maf was fine and i even changed it out just in case.
Anyways I then thought it was my computer when i couldnt even get the car to start. Anyways I installed my Megasquirt while i was down. Now that i have that i did some datalogging in order to get it to start. It showed that I have no rpm signal. I think this could be my problem. I can get the car to turn over once about , but then nothing.
A bad module could possibly give no rpm readout correct?
Old 03-18-2008, 10:56 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Re: Possible bad hei module?
The distributor supplies the spark pulse under 400 rpm. Also sends pulse to ecm for injectors.
Check/change the ignition module.
Old 03-18-2008, 11:18 AM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Thanx so my coil will not give any spark until after 500rpm?
Old 03-18-2008, 09:42 PM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
No.... Spark will come from the Dis. only, till 400 rpm. You will see your initial (base timing only). After 400 rpm it is ECM controlled (base + ecm timing).
The ignition module puts out pulses, this firers the injectors (through the ecm) and the coil (bypassing the ecm), at 400 rpm and up, ecm controls injectors and spark.
A bad ignition module will not fire either spark, injectors, or show rpm(data log) . Sometimes they just almost work, replace with a known good one.
Some after market will almost work.
New AC DELCO will always work.
To be absolutely sure remove from a running car.
Also use the approved thermo compound. Heat kills electronics.
Old 03-19-2008, 01:46 AM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Thanx man i get my new dizzy setup tomorrow. So im hoping all goes well.
gta892000
08-11-2019 11:16 AM
MM2Robinson
10-01-2017 09:16 AM
BumpaD82
02-26-2016 02:57 PM
86CamaroDan
09-29-2015 10:08 PM
TrevinE
09-14-2015 03:20 PM
Quick Reply: Possible bad hei module?
