Centerbolt Valve covers
Car: 1991 Z28
Engine: 383 TPI
Transmission: 700R4 w/2800 stall
Help!
I went absolutely crazy trying to find the magnesium L98 Corvette valve covers for my new engine, got rocker arms to accommodate the center bolt pattern, but even after trimming out the drippers the valve covers hit the rockers. I believe the Canfield heads I have have taller rocker studs than some other heads (at least that is the vibe I got from the engine builder)... In a recent camaro or GM performance magazine, they built a similar 383, but with Edelbrock heads and used the same valve covers. The magazine said they used a spacer under their valve cover, but I couldn't find a valve cover spacer for centerbolt valve covers anywhere. Only thing I could find remotely close was a hundred dollar set of adapters to fit perimeter style covers on centerbolt heads, and it only gave 3/8".
Anyone seen centerbolt valve cover spacers before, or ran into this situation? Other posts I've seen that use these valve covers typically say after the drippers go, it fits OK...
Oh, and if someone delt with a spacer before, do the runners on the TPI hit the valve covers?
Thanks!
Thanks!
Car: 87 GTA
Re: Centerbolt Valve covers
It wouldn't very be hard to machine some risers out of aluminum to space them up.
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
why stick with those with all the hassle,do you like the vette covers that much? I use a set of Jegs smooth polish covers and get alot of compliments about them. and they are only 100 bucks, you could probably sell those vette's for something around that..( or just save'm, that's what i would do)
Car: 1991 Z28
Engine: 383 TPI
I guess I'll have to do some playing around. I'm just a bit concerned the valve cover may hit the runners, but I'll look into it a bit further and see what the shop can do.
Abubaca, I gotta agree with you, on a TPI motor, there isn't anything that looks better than the mag covers, they compliment the TPI plenum like no others.
I appreciate the responses, thanks!
Hotrodboba400
12-10-2019 07:07 PM
