What Is A Good Fuel Pressure Gauge For Our Intakes?
Just what the title says. I'm looking for a good (But inexpensive) fuel pressure gauge that was designed to mount directly to the NPT fitting in the TPI fuel rail.
The Accel is def nice, but $70+ for a friggin gauge seems outta the park.
The next guy I was looking at was the Moroso, but I'm not it comes with all the necessary parts to be classified an All-In-One-With-No-Extra-Parts-Needed kit.
The Moroso looks promising, given that it doesn't require the purchase of a seperate adapter or extender to mount to the fuel rail.
Here is basically what I'm looking for:
- Something that would be permanately fitted to the car
- Something that is of good quality, and gives accurate readings (I know I read that the Moroso has a "Vibration Controlled" needle). I was told to stay away from the liquid filled ones.
- Something inexpensive but with good functionality and an all in one kit. No seperate pieces or adapters needed.
Well guys, any ideas?
Re: What Is A Good Fuel Pressure Gauge For Our Intakes?
Are you looking for the kind of gauge that mounts to the fuel rail, a separate gauge that needs a hose or one that you can mount inside the car?
The kind that mounts to the fuel rail.
Eventually later down the road when I redo my gauges the kind that mounts in the car, but that won't be for awhile.
I used to use a small gauge that mounted directly to the fuel rail with a tall elbow adapter, but the needle began to bounce around like crazy after a short while. Summit then sent me a letter telling me that the manufacturer was recalling them because they were defective and could leak and cause a fire. I had removed the gauge earlier because the bouncing needle made the gauge essentially worthless. Summit did send me a check and a cap for my trouble.....this was years after I had bought the gauge. I don't even recall who manufactured the gauge. It might have been a VDO gauge
IIRC, I read someplace that these rail mounted gauges are for temporary use only...just for testing.
I now run an Auto Meter gauge. I disconnected and capped the gauge hose because I was cleaning the injectors thru the pressure port. Sorry for the dust and rusty fasteners. I wish someone would make a cup for the back of the gauge too. Since it's liquid filled, it's pretty impervious to foreign material getting into the gauge mechanism.
Bad place for a non-weather resistant switch.
I'm looking for a fuel pressure gauge setup as well, except just a put it on, tune and then take it off kinda thing.
The good thing about the Accel unit is the it's nice and short at the 90 deg bend. Since I have a 1990 TPI the stupid map sensor is right above the fuel rail where the fitting sticks out.
http://www.jegs.com/i/DFI/310/74726/10002/-1
By the way I'm pretty sure that fitting that comes off the fuel rail is a -4AN male, not 1/8. Or wait.... don't tell me that GM put different ones on there depending on the year.... Sigh that would make GM sense.
Chuck
Chuck
Car: 6.7 Powerstroke
For that accel one, its not meant to be on the fuel rails at all times. i just bought it do check my fuel psi when i changed out my afpr and thats it. the instructions say not to leave mounted onto cars fuel rails.
9192camaro
16
02-03-2019 12:21 AM
86IROC112
08-17-2015 02:00 PM
R3500
08-17-2015 12:16 PM
