1990 Camaro Wont Start
Old 07-25-2009, 04:53 PM
Matemk's Avatar
1990 Camaro Iroc 5.7 TPI
Car has been sitting for 4+ years, so last night i took MMO and put into all cylinders and let it sit overnight, this morning i could turn the motor over by hand so i know its not seized.
Put in new battery and attempted to crank, it would turn and turn just never fire up, so i sprayed Starting Fluid down the Throttle Body, cranked it and it fired up, died about a second later.
This leads me to believe the Fuel Pump is out, i checked all fuses, VATS is working correctly, changed out Fuel Pump Relay, gave it fresh gas, depressed the Schrader valve and a drop of gas came out of it, so no pressure at the fuel rail.
I can not hear the pump "hum" when i put the key in and to the ON position.
Only thing i can think of is the Fuel Pump being dead, i am going to try all possibilities before dropping the tank(From what ive read its a PITA)
I have bought the fuel filter, just not installed yet.
What else could it be, or am i stuck with dropping the tank and changing the pump.
Old 07-25-2009, 05:01 PM
cutlassman14's Avatar
Car: 90 trans am
Transmission: 5 spd
Re: 1990 Camaro Wont Start
id try the fuel filter first
Old 07-25-2009, 05:17 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
without the humming, I say change the pump, in fact i have a 255lph for sale cheap! its brand new walbro.
let me know if you want it
Old 07-25-2009, 07:54 PM
Matemk's Avatar
Think im going to make an access hole to the fuel pump and just go with a Delphi Fuel Pump for now.
Maybe i will be able to get it running tomorrow.
Old 08-02-2009, 08:14 PM
Matemk's Avatar
Ok, did it the correct way and dropped the tank, replaced the Tank, Sending Unit, and Pump. i can hear it "hum" for a few seconds when i turn it off, but it still will not start up, i can spray starting fluid in there and it will turn over for a few seconds like before. but the pump is working now, just no start up
Old 08-12-2009, 10:44 AM
ThirdGenFire's Avatar
Car: 2000 Trans Am and a 85 Iroc-Z
Engine: The Mighty LS1& 305 just beat meTPI
Transmission: 4L60E and 700R4
I am having the same issues right now. My Iroc hasn"t been turned on in over a year and is no humming. It is a new pump that I installed 3 years ago. it ran fine for 2 years(not many miles maybe 3K) and then sat now for over a year. I am going to check the relay right now and see if it has any current with the key in the run position. I don't believe it can be the pump since it is new and just sat. I am also going to change the filter just in case. I threw my fuel pressure tester on there and at the "run position"there is no pressure when there should be. let me know what you find just in case I don't finish my problem by today.
Old 08-12-2009, 04:57 PM
Matemk's Avatar
http://www.austinthirdgen.org/index.php?pid=35
Follow that when testing, good stuff.
Mine turned out to be a dead fuel pump, replaced it and it started to HUM afterwards
Follow my other thread on this issue, has some good stuff in there also
https://www.thirdgen.org/forums/tech...y-90-iroc.html
Old 08-13-2009, 11:39 AM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Before you do anything else check the main line fuse near the battery like the message in the linked post says, a quick way to check it is if the ses light does not light up when you try to start the car.
Also a bad ignition module will not fire the injectors have that checked too.
Old 08-13-2009, 10:35 PM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
the injectors could all be gunked up with s*it too....pull the fuel rails and see if they will fire, have a friend give it a little crank you should be able to see if they fire right
Old 08-15-2009, 09:39 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
Finally got mine to crank today. The fuel injectors were stopped up with varnish.I was about ready to give up,But I cleaned the injectors myself and it fired right up. FINALLY.
Frozer!!!
01-19-2024 04:55 PM
1992 Trans Am
Exterior Parts for Sale
04-04-2016 12:50 PM
Street Lethal
08-14-2015 08:25 PM
92camaroJoe
08-13-2015 06:07 AM
Sanjay
08-12-2015 03:41 PM
Quick Reply: 1990 Camaro Wont Start
