Car not starting? Help please
Car: 1986 Trans am-Firebird
Transmission: Stock
when i go to turn my car over it starts up for about 1 second and thne dies then ill try and start it again and it does the same thing and still doesnt start. I believe my injectors are not firing when i go to turn the car over getting a noid light today so ill update if they do or are not.Cause the car will fire when starting fluid is added. What would be the cause if this.
Two things that i reason did: My egr is not connected cause the connection broke off i found out and i replaced my oil pressure switch.
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
Re: Car not starting? Help please
Did you get it started yet? I am going thru same thing will let you know what happens tomorrow
Transmission: Stock
alright thanks and i wasnt able to pick up a noid light today but i am 90% sure they are not firing there just turning on for that prime.
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
The injectors don't spray fuel until the ECM gets a reference signal pulse from the Ignition Control module which won't happen until the engine is cranking.
1 Post
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
only the cold start injector is probably working
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Did you get the noid light? It will cut the trouble shooting down to injectors only if they are firing. Got mine cranked today after using noid light it showed fire so I cleaned the injectors myself and it cranked right up.Also made sure I had 43lbs of fuel to rail before I pulled injectors.
